First post, by Squall Leonhart
DgVoodoo leaks d3d12 resources when presentation and rendering are not on the same GPU (muxless switchable graphics behavior) on
intel + Geforce configurations.
Squall Leonhart wrote on 2026-02-01, 09:13:DgVoodoo leaks d3d12 resources when presentation and rendering are not on the same GPU (muxless switchable graphics behavior) on
No, it does not. If you mean that guru3dforums (or whatever) thread, that was actually me. But I have a plain desktop machine so it's not even a muxless case, it's something that they just imagined for themselves. But even with a muxless setup, dgVoodoo runs on the same path so it should not matter.
Dege wrote on 2026-02-01, 16:29:Squall Leonhart wrote on 2026-02-01, 09:13:DgVoodoo leaks d3d12 resources when presentation and rendering are not on the same GPU (muxless switchable graphics behavior) on
intel + Geforce configurations.No, it does not. If you mean that guru3dforums (or whatever) thread, that was actually me. But I have a plain desktop machine so it's not even a muxless case, it's something that they just imagined for themselves. But even with a muxless setup, dgVoodoo runs on the same path so it should not matter.
I can assure you, yes it does.
even happens on Intel+Intel (Iris IGP Presentation + Iris Max DGPU Rendering.)
How?
What are the repro steps?
Btw, you mean leaking d3d12 resources or plain memory?
Because what I posted on guruwhatever was about leaking system memory, and that occured with an NV dGPU + Intel iGpu configuration when running the rendering on the iGPU.
MSIA hooked the D3D12 Present call and always called into NV API from the hook, so I got an internal error from an OS component for each frame presentation call, and that was accompanied with a constantly growing memory leak. When I closed MSIA without closing the demo doing the rendering then leaking memory just stopped. When I restarted it again then it continued.
Now that I happen to have an Intel dGPU + Intel iGPU setup, I "interestingly" cannot reproduce the leak. Because no NV API to call into.
(Btw, as a side note, an NV 5060Ti is practically unusable with 32 bit D3D12. The GPU just hangs or crashes when the GPU usage reaches 85-90%.)
