First post, by marooned_on_mars
First of all i have searched trough the forum and i hope there aren`t any posts like this.
I am having : DosBox 0.63
I am using : D-Fend v2
I am running on : Windows XP Sp1
When i try to run these 3 games that i have mentioned in the title , no matter how much i try they keep saing : illegal command
I will ad a photo with the problem
Reply 1 of 5, by HunterZ
If you use the dir command instead of trying to run sc2000.exe, what do you see?
Reply 2 of 5, by eL_PuSHeR
Why don't you keep all ms-dos folder names under the 8.3 naming convention? I doubt it will have something to do with your problem but who knows.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
well dfend sometimes creates different short filenames then dosbox does
Dfend isn't actually too blame or so. It's a known difference between D-Fend and DOSBox.
Water flows down the stream
Reply 5 of 5, by marooned_on_mars
ooooh ... but you are shure quick! 😁. I have tried DosFreak`s suggestion and it worked ... thanks a LOT ! 😉
