First post, by compiler
I have some problems with the sound in my "retroPC".
I have a Neoware EON Geode GX300, which it's supposed to have a CS5530 sound card (SB16 compatible).
The BIOS allows me to set SB16 emulation and set Address, IRQ, DMA, etc.
I'm using the following 3 games as a test :
- Gods with its initial theme: https://www.youtube.com/watch?v=2DexgMrYfko.
- Duke Nukem 3D's sound test in setup.exe.
- Prince of Persia 1.3 with "prince sblast".
1.- If I start MSDOS 6.22 without any driver loaded, and I set the BLASTER variable properly:
- Gods opening theme works and the first "Into... the wonderful" voice can be heard, but then the voice does not sound anymore in the theme, I only have the background music and the drums.
- Duke3d sound test works fine (both music and sfx).
- Prince Of Persia 1.3 has music and sound effects.
2.- If I load UNISOUND 0.82a in autoexec.bat, the card gets detected (as a non PNP sound card), and it shows the proper configuration parameters that I have set in the BIOS and I specified in the BLASTER variable.
- Gods doesn't have any sound.
- Duke3d sound test does not give any error but I cannot hear any sound.
- Prince of persia has no sound.
The thing is... are there specific/dedicated MSDOS sound drivers for the CS5530 that work with all games?
I could only find Windows drivers here: here.
Thanks.
