First post, by AaronS
Hello, I want to capture digital audio from my Audigy 2 ZS (I don't have the Creative front panel), I saw in one of phils videos he uses one of those brackets you can get off ebay/aliexpress:
https://www.youtube.com/watch?v=RfmYYG1rVug
Do all of these brackets work (he's using an ASUS one in the video but there's other non branded ones I'm finding), and is there a guide to which pins I need to connect so I don't damage anything?
Reply 2 of 10, by AaronS
Thanks, I ordered one of the cheaper black PCB ones, they're like half the price of the Asus ones that have a large capacitor on them, hopefully works with my setup. My only slight concern is I need to install it behind the sound card bracket and hope those wires can stretch that far.
Reply 3 of 10, by Stretch
Alternatively, you can also use a mono 3.5 mm to RCA adapter and connect the cable to a coax to optical converter.
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - ESI Maya22 USB
Reply 4 of 10, by ott
Stretch wrote on 2026-04-23, 22:55:
The official manual (PDF) allows this method for connecting 2.0/2.1 speakers, but I'm concerned because the DIGITAL OUT jack on the Audigy2/2ZS cards is a 4-pole jack and provides three S/PDIF outputs (6 channels). This connection is used for Creative's 5.1 digital speakers.
The attachment For Digital speakers.jpg is no longer available
With a 3.5mm mono jack plug, all three digital outputs will be shorted to single pole, which is probably not good (I hope there's protection for this).
I'd rather use a 3.5mm 4-pole jack plug to 3x RCA A/V cable - fortunately, it's ideal for connecting three S/PDIF outputs:
- SPDIF#1 (red RCA): Front channels (Left, Right)
- SPDIF#2 (white RCA): Center, LFE
- SPDIF#3 (yellow RCA): Surround Left, Surround Right
The attachment av-cable.jpg is no longer available
Reply 5 of 10, by shevalier
And what exactly should be at the end?
If you just need a recording, Creative sound cards have a special source in the control panel called “Wats-U-Here”.
This returns a fully processed audio stream from the DSP.
If you’re sending it to, say, a ‘receiver’, then multi-channel audio won’t fit into SPDIF; you’ll need Dolby Digital or DTS encoding.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 6 of 10, by Joseph_Joestar
ott wrote on 2026-04-24, 12:11:
I've been using a set of Cambridge SoundWorks Digital 2.1 speakers with SBLive/Audigy cards for years. The speaker manual confirms that mono 3.5mm to RCA is the official connection method for SBLive cards.
The attachment SoundWorks_Manual.jpg is no longer available
Not sure if the Audigy cards are wired differently, but I've connected an Audigy 2 ZS to those speakers using the same method and haven't encountered any issues.
My retro builds
Reply 7 of 10, by ott
Joseph_Joestar wrote on 2026-04-24, 12:40:
Thanks, I will keep it in mind.
In addition to my previous post, I found description of the DIGITAL OUT jack on the Creative's knowledge base:
https://support.creative.com/kb/ShowArticle.aspx?sid=5764
Reply 8 of 10, by AaronS
Arrived and working in DOS 6.22 with VSBHDA, Windows 98 and XP.
As expected, the wires aren't long enough to route it behind the Audigy card, I've had to remove my PCI GPU for now. What are these wires called so I can get some longer ones?
Reply 9 of 10, by shevalier
AaronS wrote on 2026-05-06, 15:57:
Arrived and working in DOS 6.22 with VSBHDA, Windows 98 and XP. […]
bls dupont Female to Female cable
https://www.amazon.com.au/uxcell-30CM-Length- … r/dp/B007Q84AUU
https://www.amazon.com.au/uxcell-Jumper-Femal … /dp/B08MZPJFMR/
https://www.amazon.com.au/RLECS-Dupont-7-9inc … r/dp/B0DGGCM12Z
https://www.amazon.com.au/ZYAMY-Dupont-Connec … d/dp/B0789F523N
Reply 10 of 10, by ott
I'm not sure if I can provide Amazon links, but the best solution is probably to get 10-Pin (2x5) IDC ribbon cable, the extension version.
FC-10P connector has low height (unlike Dupont) and doesn't block the installation of long cards, which can be important.
The attachment 51olVkCHsPL._SL1082_.jpg is no longer available
If you have soldering experience, you can make your own cable from the motherboard COM port cable, following the pinout of both devices.
The attachment fc-10p.jpg is no longer available
