First post, by Lostdotfish
Has anyone had a go at building one of these?
The attachment Screenshot 2026-05-06 122810.png is no longer available
https://bitsundbolts.com/2025/07/01/the-small … xpansion-board/
I just ordered some PCBs and I am wondering if the RAM ICs on these old 72pin SIMMS would be compatible?
The attachment Screenshot 2026-05-06 122613.png is no longer available
They are 32MB EDO RAM and there are 16 ICs per stick (8 on the front and 8 on the back). So to my mind that means they are 2MB per IC which should be correct for building the Minuet board.
Reply 2 of 3, by Lostdotfish
Shponglefan wrote on 2026-05-06, 14:28:
If you're planning to cannibalize 72 pin simms, why not just get something like the simmconn adapter: https://www.serdashop.com/SIMMCONN
Then you can just use 72 pin simms directly.
I don't like the bulky footprint and the price of the simmconn...
5 PCBs for Minuet - £4 delivered
BOM for assembly - probably less than £2 per card
