First post, by timdog
Greetings,
I'm putting together my first retro 486 machine similar to one I owned about 30 years ago. I sourced all the parts on eBay and went to post for the first time yesterday to no success. I'm getting an error code of 8 beeps and from what I can see of AMIBIOS circa 1993 this means bad VRAM or missing video card. Nothing on the monitor either. I have a Diamond SpeedStar Pro VLB that seems in decent condition plus a Lucky Star UM8498/8496 Socket 3 motherboard that was tested and working when I purchased it. I've tried all 3 VLB slots and I've tried all possible VLB jumper settings on the motherboard regarding 0/1 wait state and VLB bus less than or equal to 33mhz (I have an AMD 486 DX4 100 CPU currently installed.). I've cleaned the connectors on the card as well even though they look pretty clean already. Does anybody have any suggestions? I'm at the point where I feel like I need to try another video card but I don't have access to one and don't really feel like spending $50 on ebay just as a tester.
Thanks for any help!
Reply 1 of 13, by Babasha
1) There is something strange with xtal near thr main chip.
2) Try to reseat and clean the contacts of ROM chip
Need help? Begin with photo and model of your hardware 😉
Reply 2 of 13, by timdog
Thanks for the tips.
You are right. It does look like something swiped the oscillator and marked the main chip. When looking on retro web for pictures you can see the difference. The mark on the main chip seems superficial to the touch. I don't feel any scratches there but maybe the oscillator got damaged? I will reseat the ROM as well.
Cheers
Babasha wrote on 2026-05-17, 16:37:
Reply 3 of 13, by BitWrangler
There's something going on, on the other side of the chip to the crystal, dented or solder blobbed pins, not quite enough detail to make it out.
Reply 4 of 13, by Tiido
That 14.31818MHz crystal looks to have been pushed hard enough that it has its pins rip out of its casing, and whatever caused it, left a skidmark on the Cirrus chip afterwards...
These crystals are mounted flush on all boards I have seen and there is no wiggle room to get such an orientation. My money is on the crystal being destroyed, rest of the card looks pretty good.
Reply 5 of 13, by TheMobRules
I have some cards where they put some kind of "spacer" between the crystal and the board, maybe to protect it from heat during wave soldering phase? This one appears to have been knocked though.
Reply 6 of 13, by timdog
Tiido wrote on 2026-05-17, 20:23:
It certainly seems damaged to me after looking close. I've found the crystal part online for less than a buck. Do you think it would be a straightforward solder job?
Reply 7 of 13, by jakethompson1
It should be. I would personally use an "Engineer" hand pump solder sucker and a syringe of no-clean rosin flux to desolder it.
Reply 8 of 13, by Eep386
Did you check pin 2 of the GD5428 chip to see if it's still firmly soldered (visual inspection is useless, use a thin needle or hobby knife blade to see if it moves)?
Pin 2 is /EROM, which enables the ROM socket. The scrape on the chip looks like it hovers perilously close to the pin, as well as pin 3 (D15) - might want to check that as well.
Reply 9 of 13, by rasz_pl
As Eep386 noticed already whatever swiped crystal also ripped pins off the pcb pads on main chip corner near crystal
Reply 10 of 13, by timdog
Eep386 wrote on 2026-05-18, 13:11:
I was able to test the first 4-5 pins on the chip with a needle and they do all seem solid to me. No movement at all. I also inspected the oscillator much closer and although the connectors are bent, it is still solid and not loose at all. No signs of compromise on the casing. If I look a bit farther down the board where the scrape is I do see something new. One of the tantalum caps has clear damage to it. A significant score. You can actually see more tiny scrapes on the chip behind it too. Any thoughts on this? I could probably check it with a multimeter.
Thanks
Reply 11 of 13, by Eep386
That cap being dinged shouldn't prevent the board from working entirely.
Most of the big splodeytant caps are just smoothers and won't outright prevent operation.
It's possible the GD5428 itself is stone dead. I've been noticing a fair number of dead and dying GD5428 and GD5429 GPUs.
Before going down that route though, did you try dumping the BIOS? If the BIOS ROM chip is suffering bit rot it probably won't work even with a healthy GPU.
It is also possible one or more of the bus buffer chips (those 74F245 DIP chips) are bad. I've had to replace a few of those in the past on various things. To find out for sure you'll need an o-scope.
Also, can you please post a picture of the rear of the board? Busted traces can be _really_ tricky to spot.
Reply 12 of 13, by timdog
Eep386 wrote on 2026-05-30, 16:59:
That cap being dinged shouldn't prevent the board from working entirely. Most of the big splodeytant caps are just smoothers and […]
My window for returning the item via eBay is in a couple days and I've decided it's not worth trying to fix. Thanks for the tips!
Reply 13 of 13, by jakethompson1
Good news is there are plenty of other 5428 VLB cards on ebay. Because of the integrated RAMDAC, it's less relevant that it be a brand name than some other cards of that era.
