First post, by theelf
Hi watch the video
https://www.youtube.com/watch?v=aIq8x8VFu4M
min 3.43, any ideas? never see this, i know other shell, but never find one that look like program manager plus this nice things
greetings
Reply 1 of 7, by NeoG_
I don't know which specific program it is, but there is programs which add information to the title bar area of all applications, you can see the same information shows in the OPTi Media Rack title bar at 4.40
This is an example but it's only the clock: https://www.owenrudge.net/utils/tbclock
Reply 3 of 7, by MrKsoft
That is "Plug-in for Windows" by Plannet Crafters.
The OPL Archive - Preserving MS-DOS music in a unified format!
Reply 4 of 7, by theelf
MrKsoft wrote on 2026-05-21, 01:13:
man this is amazing!!! 30+ years windows 3.1 user and this if first time to know about this software
Is amazing!! nested groups!!!
thanks a lot!
Reply 5 of 7, by Cyberdyne
https://www.sac.sk/files.php?d=16&l=P
Reply 6 of 7, by theelf
thanks a lot! now the hard process of find a serial, crack or whatever
Sadly im not in home to test until next month, outside because work, really want to go back home and turn on the 486
Reply 7 of 7, by MrKsoft
theelf wrote on 2026-05-21, 08:54:
You're in luck. When Plannet Crafters went under they posted up a serial for it. 😀
https://web.archive.org/web/20000304055259/ht … annetarium.com/
Should have mentioned that in my first post. I had a memory that they had made it free, but didn't want to break any rules accidentally so I needed to go find their old website address and double check.
