First post, by Demonslayer2103
I have a awe 64 card and a sblive installed in the same pc so I can use the awe 64 for dos games and the sblive for windows games with eax. But I also want to use soundfonts from on the sblive on dos games since I dont have any ram for my awe64. The problem im facing is that I need the sb16 emulaton working to use soundfonts is dos games. but when I go to install the dos drivers for the sblive the sb16 emulaton does not show up unless I have the awe64 disable in device manager. Is there a way to make is so the sblive sb16 emulaton is not disabled when the awe64 is enabled at the same time?
