IBM XT 5160
First post, by JAKra85
My old IBM XT was sitting in the attic for ~10 years.
This is the No.1 PC in my retro PC collection:
https://docs.google.com/document/d/1ara32t4rV … nU/edit?tab=t.0
Today I brought it down, did a clean, disassembled made photos, reassembled.
Changed the videocard to ATi Wonder 1024 - ISA - 512KB (PN 109-00095-10).
One of the fastest videocards possible from ATi for the original IBM XT (CPU), has 512KB RAM.
This is a 16b ISA working in 8b ISA mode. Has both VGA and EGA outputs.
(Tried IBM 5151 monitor and an LCD at the same time, does not work. 😜 )
The HDD was stuck, did not spin. WD40 on the axis and a 10 minute manual spin solved the issue.
The FDD was also suck. It did spin, but the stepper motor was stuck. WD40 plus some grease on the head rail a bit of back and forth movement solved the issue.
Motherboard:
The attachment 20260524_134337.jpg is no longer available
Videocard:
The attachment 20260524_134536.jpg is no longer available
RAM cards (2x256KB):
The attachment 20260524_141431.jpg is no longer available
Working (again) IBM XT:
The attachment 20260524_212223.jpg is no longer available
The attachment 20260524_212529.jpg is no longer available
Will do a few more pictures tomorrow during daytime.
Also, planing a 8087 FPU upgrade soon.
