First post, by secondwave
I’ve been slowly developing a small retro hardware project called VoltBus for the IBM PCjr and wanted to share the next piece I’ve been working on: VoltHub.
The idea behind VoltHub is pretty simple:
cleaner internal power routing
fewer loose splitters/adapters
integrated fan control
easier expansion for future mods
cleaner cable management inside cramped retro systems
Right now this is still very much a hobbyist/development project and I’m mainly focused on:
layout testing
connector placement
usability
airflow/fan control
visualizing how future modular upgrades could work together
The current concept includes:
LP4/Molex power distribution
Berg/floppy power
auxiliary/test outputs
fixed and adjustable fan headers using an LM317 circuit
expansion/power bus headers
compact modular stacking with VoltBus power passes through the link directly with no wires
I’m also experimenting with keeping the design somewhat cross-compatible between future systems/projects instead of making completely separate standards for every machine. The board can be powered through the voltbus or as a stand alone unit through LP4.
A few renders attached. These aren’t intended to be photoreal marketing renders, mostly just clean visualizations of the concepts and layouts while I continue testing and refining things.
I would genuinely love feedback!
