First post, by Rolling
Looking for some oldschool Sierra nerds out there... 😉
I'm trying to get a DOS version of King's Quest VII with german language to work, but i'm kinda stuck in SCI limbo.
Some basics regarding the version differences of KQ7:
- 1.0/1.1 - very buggy, probably Win3.1 only
- 1.4 - a lot of the game recoded, patches fixed, Windows only
- 1.51 - more bugs fixed, a few parts/deaths removed, puzzles changed, Windows only
- 2.0 - definitive version (firecracker fug gixed) with SCI interpretor for Windows and DOS
One advantage the windows versions have is, that they use higher quality AVIs for cutscenes, while DOS uses RBTs, which are not as of high of quality.
Of course there were also international releases with different languages, but sadly only the english version 2.0 has been released as enhanced version. International releases are 1.4 or 1.51.
So what's my goal here? I have the german version 1.51 which only comes with an interpreter for Windows but i'ld love to get the german version running on DOS.
I can get the english version 2.0 to run fine without CD as described here. I tried copying the german RESOURCE.* and ALTRES.* files over the english version which results in an SCI-Error:
The attachment Screenshot 2026-05-30 173113.png is no longer available
I also tried it the other way around, installing the german version and then bringing the DOS interpreter from version 2.0 to the directory, but this results in same error.
There is a patch, which in theory updates KQ7 v1.4 or v1.51 releases to v 2.00b with the DOS interpreter, but it only seems to work for the english or spanish versions of the game. If i try running it with my german 1.51 it installs fine but i'll get this error on startup:
The attachment Screenshot 2026-05-30 174709.png is no longer available
Any ideas on how to proceed?
Reply 1 of 17, by MagefromAntares
Hi,
According to https://wiki.scummvm.org/index.php?title=Sier … sions#SCI_Games King's Quest VII is using SCI21(Version:2.100.002) as an interpreter, that page lists the
2.100.002 	King's Quest VII [German, Windows Only release] 	1.51 	1994-11-17
German version as Windows only, it is possible that the game is only compatible with the Windows version of Sierra's Creative Interpreter. Also to note that this page lists version 1.4 without mentioning as Windows only, it might be simply an oversight, but it is possible that version 1.4 had also a DOS interpreter version, and that is a lot smaller version difference than between 1.51 and 2.00b, if that is the case then the interpreter bundled with 1.4 might be able to run the game, just a small possibility however unfortunately 🙁.
EDIT: Also note that the German version is in the SCI21 (early) category, while the 2.00b DOS version is in SCI21 (middle) category, the interpreter version is supposed to be the same, but the comment at the beginning suggest that the two games have different interpreter kernel function tables, which might explain the incompatibility.
"A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it." - Dune
Reply 2 of 17, by Rolling
I did some further testing with english 1.51 version, which also seems to use interpreter version 2.100.002 according to the list.
With this custom installer it actually works fine. It gets upgraded to 2.00b during installation and works with the provided DOS interpreter.
So i guess the question would be: What does this magical installer do, that works with the english and spanish 1.51 windows-only versions, but not with the german release of the same version level?
Reply 3 of 17, by MagefromAntares
You might also want to post about this issue on https://sciprogramming.com/, while they primarily seem to focus on older versions of SCI, they are actually making new games using that interpreter, so it is possible that you can get some help quicker on the forum of that page. And I don't think there is a disadvantage of posting this issue to multiple avenues for help.
Reply 4 of 17, by digger
I don't think even the later SCI games ever required 3D acceleration or any other APIs beyond what is available in Windows 3.x, or do they?
If they indeed don't, perhaps the Windows 3.x SCI executable of the game might run on the HX DOS extender. Has anybody tried that yet?
Reply 5 of 17, by Rolling
I tried using HX extender but the game crashes even earlier:
The attachment Screenshot 2026-05-31 113505.png is no longer available
I also tried registering an account on sciprogramming.com but still waiting admins approval.
Reply 6 of 17, by Spikey
Should run in DOSBox, which supports Win 3.x.
Reply 7 of 17, by myne
Might be worth looking at the resource files to play spot the difference.
Obviously the German and English text will be different, but it's the rest that should be the same and obviously isn't.
I can't imagine they used a super complex database. It probably amounts to an array of strings someone could throw their brain at and sus out pretty quickly.
Can you post the 2 smallest equivalent ones? Ie small German and English of the same file.
I built:
Reply 8 of 17, by Rolling
Had no luck with sciprogramming.com, because sadly no one approved the creation of my account. 🙁
Spikey wrote on 2026-06-04, 06:48:
I know, that it works with Win 3.X in DOSBox, because i successfully tried that, but i'm trying to get it to run on real hardware under DOS.
myne wrote on 2026-06-04, 07:25:
I'm not quite sure, what that means. What should i post exactly? These are the resource files for both versions:
The attachment diff.png is no longer available
All of them (even the ones with same file size) differ quite a bit from each other. I suppose it could be a codepage thing, but i'm not sure, if there isn't more to it (version differences, etc.). I fear that all these RESOURCE files are deeply intertwined and it'ld probably need an absolute SCI crack to figure this out.
Reply 9 of 17, by MagefromAntares
Rolling wrote on 2026-06-05, 07:25:
Had no luck with sciprogramming.com, because sadly no one approved the creation of my account. :( […]
It is unfortunate that sciprogramming.com doesn't approved your registration, the only other community with the necessary skills to debug this that I know of is the ScummVM one(https://wiki.scummvm.org/index.php?title=King%27s_Quest_VII), you could try contacting them on their forums(https://forums.scummvm.org/), hopefully they will approve the forum registration there, one thing to note about them though is that they are mostly interested in getting the older adventure games running on their ScummVM engine and helping people to run on actual DOS is not their primary interest, so it is very possible that they will handle your request to help as low-priority, but now I cannot think of anyone else on the top of my head who are able to help with an issue that most likely needs a very in-depth knowledge of the SCI engine to debug.
Reply 10 of 17, by myne
I meant zip them, and attach them here.
I built:
Reply 11 of 17, by Rolling
Ah, sure, no problem. I took the two smallest ones (RESOURCE.MAP and RESOURCE.MDT) from both versions. Here you go:
Reply 12 of 17, by myne
00 25 00 01 ef 23 02 df 27 04 fb 2c 06 d7 41 07 ef 41 09 2b 42 0b 3d 42 10 73 42 11 f9 43 ff 15 49 f5 17 00 00
00 25 00 01 c5 23 02 c7 27 04 e9 2c 06 c5 41 07 dd 41 09 19 42 0b 2b 42 10 61 42 11 e7 43 ff 09 49 df 16 00 00
Assumption: The headers are different already.
It's unlikely, but maybe swapping the eng header to the ger would work.
Usually there's other details like "this DB is X long"
I built:
Reply 13 of 17, by Rolling
I tried, but ended up with the same results, see first post.
Reply 14 of 17, by myne
https://www.akril15.com/kq7resources/KQ7resources.html
https://sciprogramming.com/scitools.php?id=2
seen that?
I built:
Reply 15 of 17, by Rolling
I've tried to use SCI Viewer to dig around in the RESOURCE files. Script 15 (see error message in first post) seems to be the logo, but the tool says it's identical in both versions.
The attachment Screenshot 2026-06-06 093144.png is no longer available
I fear, that you'ld need to learn a lot of SCI related stuff, which i hate to say, but is probably above my head at the moment.
Reply 16 of 17, by myne
This is just dumb enough to work.
Try changing the language in the cfg file.
I personally suspect everything is in the resource.000
I built:
Reply 17 of 17, by Rolling
Good idea! Sadly, that won't change anything. Since the windows version doesn't have a RESOURCE.CFG, you have to take the file from an english release or download it from here.
It doesn't seem to matter if you set language=1 (english) or language=49 (german) or even omit the parameter at all.
I tried using all parameters from RESOURCE.WIN for RESOURCE.CFG, but that also won't change anything. The game seems to load at least until short before the logo when the "out of movable memory error" hits.
