First post, by sblack
I have a program called STSPlus available at www.dransom.com it is a satellite tracking program. The program works great on dosbox except for one thing. In the map display it gives you the option to show the Time since orbital element (T+E) was created or the Mission Elapsed Time (MET). In the program you switch this by pressing the F5 key when you are in the map display. When I run the app inside dosbox this doesn't function, but if I run it in dos mode it switches fine.
Does anyone have and idea if there might be a config setting or something to enable this?
Thanks for your help!
Reply 1 of 2, by DosFreak
Could you try one of the CVS builds in my signature?
Preferably gulikoza's?
If that doesn't work have you tried remapping the F1 key by using the internal DosBox Keyboard mapper? Just press CTRL+F1 while in DosBox to remap the F5 key to another key.
Make your games work offline
Reply 2 of 2, by sblack
Thanks gulikoza's build worked great! the F5 key switches the times just like it should.
