First post, by myne
Been playing around with an inf file to install dos AFTER win9x.
I get... bored.
I think I figured it out. Ie it worked once.
BIG CAVEAT! I assume this will only work on FAT partitions. NO FAT32.
Instructions:
Copy all into a folder. Add dos 6.22 files from floppies without overwriting.
In win9x rightclick the inf > install.
It should create a c:\dos folder, mod the msdos.sys, and copy the standard dos boot files.
Assuming it works on other machines, you will have installed dos after 9x which is... kinda cool.
THIS IS TEST QUALITY. IT SHOULD NOT BREAK ANYTHING BUT IF IT DOES, THAT'S ON YOU.
My apologies to the 3 people who downloaded the file before.
I believe the msdos.--- was missing. No idea why that's important. It might also have been WinA20.38_.
IF you tried it you might have to fix the boot.
How:
Boot from CD/floppy.
c:\> c:\windows\command\sys a: c:
Should be fine then.
Deleted pending tests.
I built:
