First post, by voodoodrul
I’ve experienced this with every sb live card I have, but I don’t hear much about the tempo/pacing/timing issues when people refer to sb live cards and the lackluster fm synth. Are certain models or hardware combinations more or less prone to this issue? I’ve tried a variety of drivers and some cause opl2 to run slow as well. Opl3 in Descent plays about 50% of the speed it should run at. This is on a p3 600 slot 1 with a 440bx.
I’m mostly just looking for context on the issue if anyone has the knowledge.
Reply 1 of 9, by Joseph_Joestar
voodoodrul wrote on 2026-06-13, 05:50:
While the SBLive FM Synth emulation does indeed have slowdown problems (which may depend on the driver version), Descent is not a good example to test this. The music in that game slows down even on sound cards with genuine OPL3 hardware. Relevant info in these threads:
Anyone have a idea why the music tempo in Descent fluctuates so bad on OPL?
Re: Opti 82C929A - DOS driver anyone please?
As for the SBLive issue, I found that using the Audigy DOS drivers can mitigate the slowdown, at least in some games. See my guide for more details.
My retro stuff
Reply 2 of 9, by voodoodrul
Joseph_Joestar wrote on 2026-06-13, 06:09:
While the SBLive FM Synth emulation does indeed have slowdown problems (which may depend on the driver version), Descent is not […]
The legend himself 😂 - Thanks. I ended up going combo SB Live and YMF744 with SB-Link. I never used to have issues with OPL2 or 3 in Windows with the Live, but even that was getting laggy with weird instruments. So I decided to give up and let the Live do Windows only, YMF do DOS only.
I guess the part that was surprising to me is how different each model of SB Live (even with same EMU10k1) can sound and how unpredictable it can be. Previously I was not swapping between models to side-by-side compare, but CT4780 sounds very different from SB0060, even on the same driver versions. A table of best model + driver combos would be interesting, even if subjective.
Reply 3 of 9, by leileilol
oh it's definitely a real issue. it's not real opl3 so it struggles emulated with huge timing. It definitely happens on live 5.1 and i've never recommended this card for dos. I got sick of this issue in 2001 (begrudgingly going GM where I can) and had started to hope for something like a dos emulator to exist as I feared these issues would get worse.
Reply 4 of 9, by NeoG_
leileilol wrote on 2026-06-16, 04:27:
oh it's definitely a real issue. it's not real opl3 so it struggles emulated with huge timing. It definitely happens on live 5.1 and i've never recommended this card for dos. I got sick of this issue in 2001.
There is a significant improvement using the later audigy driver package for Live cards in DOS, it doesn't slow down OPL like the Live drivers
Reply 5 of 9, by Riikcakirds
isn't it mentioned in old threads on Vogons that when using the sbeinit emulation picking OPL2 in games that offer it instead of OPL3 makes the sound more accurate ? (most dos games almost always use OPL2 anyway)/
Reply 6 of 9, by leileilol
i've heard the slowdown on opl2-stuck games, i don't think it'd matter. The slowdown's much like the earlier AudioPCI ECW-based TSR behavior.
Reply 7 of 9, by NeoG_
Riikcakirds wrote on 2026-06-18, 16:41:
OPL3 sends more data to the FM chip than OPL2, so if there is a bottleneck OPL3 will be worse. But there are other options like using different drivers.
Reply 8 of 9, by BinaryDemon
Does a faster cpu make a significant difference?
Reply 9 of 9, by Riikcakirds
I've tried a few dos games and OPL2 emulation is definitely more accurate than OPL3, (still not great but a lot better than OPL3). You can eaily test it running the setup program in Duke3d. Under Music device select Adlib or a card that only uses OPL2 and play the music vs SB16 as music device. It doesn't slow down compared to SB16.
I think most DOS games but a rare few only used OPL2 for music even if the setup program offered options for SB16 and OPL3, so you'll get a better experience selecting Adlib.
I tested this using an Audigy2zs and sbeinit V5. I don't know if there are differences, or more accurate sound using an SBLive and sbeinit versions (V3,V4 or V5),
