First post, by Ahrle
So, after 15 years dreaming of these things, this pile is finally collected.
No prior MIDI experience, and can't get this to work properly.
The attachment 731323484_4491325421113999_352329552178424168_n.jpg is no longer available
I've chosen MT-32 and SC-55 MK1 to begin with (same region i.e. no hassles with voltage, SC-55 MK2 and SC-88 are both Japanese so may look into that)
Setup as follows:
486 with CT3900 and Lo-Tech MIF-IPC-B
Straight cable from MIF-IPC-B to MPU-401
Midi cable from MPU-401 to the MIDI module
Result with SC-55 + headphones:
Simcity 2000: No MIDI at all.
Doom: No MIDI at all.
Keen 4: No MIDI at all.
Windows MIDI, such as Canyon.mid: Playing, but missing notes and wrong instruments.
Full Tilt Pinball: Same as above - playing, but missing notes and wrong instruments.
Result with MT-32 + 2x6.3 to 3.5mm:
No MIDI at all in any application. Line unmuted and games set up for MT-32.
What am I doing wrong?
Project 357575: ECS UC4914-G | i486DX2-66 | ET4000/W32 | CT3900
Main: IBM PC300PL | PIII 750 | Viper AGP + V2 SLi | CT4500
Reply 1 of 3, by keropi
missing and wrong instruments sound like a port conflict to me, are you sure the CT3900 has the MPU active (or disabled) and on a different port than the roland mpu?
anything changes if you remove the CT3900 completely?
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 2 of 3, by Ahrle
keropi wrote on 2026-07-06, 11:40:
Thanks, was easier than I thought!
Removing ct3900 indeed got mpu going, also Windows found and installed it.
Soundblaster initially refused port 300, but now took it out and realized it was a jumper problem.
Even mt-32 is playing now! First time hearing one in person.
I know the sc-88 needs resoldering due to being Japanese (different voltage).
How about Sc-55 mk2?
Is it ok to just stick in mk1 EU adapter in there?
Reply 3 of 3, by keropi
Ahrle wrote on 2026-07-07, 11:44:
Thanks, was easier than I thought! Removing ct3900 indeed got mpu going, also Windows found and installed it. Soundblaster ini […]
great, glad you solved the issue
the SC-55 can use the same psu as the mt-32 , these operate on 9v unlike the sc-88 that has the psu internally
