First post, by sotargy
I cannot run "Pinball Fantasies" through DosBox. The graphics seem spoiled, to be exact no matter if sound is on or off. Is there any incopatibility or something? Could anyone recoment a solution?
Thank you
Thank you
It doesn't even start for me under WinXP, no matter what I tried.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Are you guys kidding me?
fullscreen=false fulldouble=false fullfixed=false fullresolution=1024x768 output=surface hwscale=1.00 autolock=true sensitivity= […]
fullscreen=false
fulldouble=false
fullfixed=false
output=surface
hwscale=1.00
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt[dosbox]
language=
machine=vga
captures=capture
memsize=16[render]
frameskip=0
aspect=false
scaler=normal2x[cpu]
core=normal
cycles=3000
cycleup=500
cycledown=20[mixer]
nosound=false
rate=22050
blocksize=2048
prebuffer=10[midi]
mpu401=true
intelligent=true
device=default
config=[sblaster]
type=sb16
base=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050[gus]
gus=true
rate=22050
base=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRASND[speaker]
pcspeaker=true
pcrate=22050
tandyrate=22050
disney=true[dos]
xms=true
ems=true[modem]
modem=false
comport=2
listenport=23[directserial]
directserial=false
comport=1
realport=COM1
defaultbps=1200
parity=N
bytesize=8
stopbit=1[ipx]
ipx=false
Did you run SETSOUND?
