Jack Orlando
First post, by ASM
There's a graphic problem with Jack Orlando.
I have attached a screenshot which shows the setup program. GAMEMENU.EXE produces similar output.
I noticed the same problem already some time ago with the 16-bit vesa patch.
However in-game movies (like the intro) work correctly.
AFAIK Jack Orlando uses VESA mode 0x110 or 0x111.
Additionally when I try to run GED.EXE (the real game executable) DOSBox quits. I tested it with different cores but the result was always the same.
I have attached the error output sent to DOSBox' console.
I'm using recent DOSBox CVS without any patches.
    131.38 KiB
    errordos32a.txt
    291 Bytes
    141 downloads
    Error output when starting GED.EXE with DOS32A (v9.1.1)
    errordos4gw.txt
    1 KiB
    144 downloads
    Error output when starting GED.EXE with DOS4GW
