First post, by cmw
- Newbie
Hello!
I used to build my own dosbox executables and it always worked but with the newest CVS snapshot i get this error while compiling:
int10_vesa.cpp: In function `void INT10_SetupVESA()':int10_vesa.cpp:441: error: `CB_RETN' undeclared (first use this function)int10_vesa.cpp:441: error: (Each undeclared identifier is reported only once for each function it appears in.)int10_vesa.cpp:441: error: `CALLBACK_SetupExtra' undeclared (first use this function)make[3]: *** [int10_vesa.o] Error 1make[3]: Leaving directory `/c/unixshell/dosbox/dosbox/src/ints'make[2]: *** [all-recursive] Error 1make[2]: Leaving directory `/c/unixshell/dosbox/dosbox/src'make[1]: *** [all-recursive] Error 1make[1]: Leaving directory `/c/unixshell/dosbox/dosbox'make: *** [all] Error 2
I'm using Win XP SP 2 with MingGW and MSYS, gcc 3.4.2.
It worked with last week's CVS.
I'm using sdl_net, but not libpng and not sdl_sound, also ddraw is not enabled i think.
Any suggestions?
Edit: Figured it out, the tarball (although the newest one) did not contain the correct (7 hour old) version of callback.h, i made the changes lately apllied by hand and it now compiles.
best regards gmw
