You could check the insides. Sometimes taking it apart and putting it back together fixes it. But if you see damage in there, it's most likely on the button part, where the spring rides in a path, which is the "action" of the switch.
To open it, you gently fold the ears (using a pin or small screwdriver) and pull it apart , slowly.
The attachment 20260727_181135_1.jpg is no longer available
This next type of switch is a bit tougher to open AND reassemble. You push the grey part in/black part out while pulling, one side at a time. On both these switches, the spring has to sit on the bottom on the "c" shaped spring piece, which applies tension
The attachment 20260727_183156_1.jpg is no longer available
Replacing it is the easiest option and guarantees success.
Daily Units:
ASUS P55TVP4, P-MMX233, Matrox2064W, CT2770
ABIT IS7, P43.2(SL7E6), PNY6600GTS, Audigy(0090)
ASUS M2N-SLI, A64X2-5600+, EVGA 8600GTx2, Audigy2(0240)
ASUS ST-990FX, FX-8350, MSI GTX760x2, SB X-Fi(0460)
MSI Z690, i9-12900K, MSI RTX3090, SB AE-7
