First post, by Mike_
Since Alcohol 120% retro edition is free while the normal version is not, I tried to use it to burn a copy of a CD in my Ahlon XP based retro system, and it crashed in the middle of the burn. I tried Nero as well, and the same thing happened, so it's not about software. Then I tried disabling DMA for the optical drive (a Samsung DVD-R drive from 2006) and everything worked fine.
Curiously enough, this only affects writing, not reading a disk.
Motherboard (GA-7ZXE 2.1) has VIA KT133A chipset which has some reputation for DMA bugs, but can it be quite *that* bad? Also, while PIO mode is probably good enough for an optical drive, is there some workaround for this?
