First post, by appiah4
The Diamond Viper PCI (Weitek 9000) has a OTI807X to handle 2D DOS tasks but this part of the card is pretty crippled, running with only an 8-bit 256K RAM. Checking the card's specs, it can also run with 512K 16-bit and 2MB 32-bit RAM configurations. This card comes with 2 256x4 RAMs and unpopulated footprint for 2 more unpopulated ram chips. I am wondering if anyone tried adding two more 256Kx4 RAM to it and upgrading it to 16-bit? I would think this would CONSIDERABLY improve its 2D DOS performance?
Reply 1 of 8, by Tiido
It looks like you only drop in the chips and it'll work, I definitely see no reason it wouldn't. I have done similar on an earlier Oak chip with success.
Reply 2 of 8, by Babasha
appiah4 wrote on 2026-08-10, 07:52:
The Diamond Viper PCI (Weitek 9000) has a OTI807X to handle 2D DOS tasks but this part of the card is pretty crippled, running w […]
You can try to solder two sockets and install two more chips
Anyway I don't think you got real DOS performance boost
It GUI accelerator with very limited DOS support
Need help? Begin with photo and model of your hardware 😉
Reply 3 of 8, by appiah4
Tiido wrote on 2026-08-10, 13:49:
Thank you, I will try this and report back with how much the performance improvement will be..
Reply 6 of 8, by Babasha
More interesting part is to use P9000 for DOS gaming
Reply 7 of 8, by appiah4
Babasha wrote on 2026-08-15, 16:15:
A lot of the VESA mode hacks he is using require a scaler. Forcing Weitek 9000 to handle DOS VESA modes and using VESA 320x200 mode is interesting though.
Reply 8 of 8, by rmay635703
appiah4 wrote on 2026-08-15, 20:49:
Scaler or one of the rather rare 15khz - 42khz ish VGA multisync monitors
