First post, by elora
- Newbie
Hello!
Bit of an obscure game here but I figured the problem might be something obvious and generalised that I'm just not thinking of.
I'm playing the game on my Windows 11 (25H2) computer, using otvdm v0.9.0, with the game installed in C:/pilgrim. I have absolutely no problems with playing the game, and had it running without problems for about an hour until my first end game screen. Upon trying to open the load game menu I receive the error
"C:\PILGRIM\LSTICON\
Insert CD number 1 in CD Drive."
This obviously doesn't make much sense, because the game won't run without disc 1 being present 🤣. Moving all of my saves out of the save game folder and opening the game fresh does let me open load game menu, but obviously there are no saves in that menu to load. The second I put any of the saves back in or create a new save this error reappears.
To be a little more detailed, if I delete every file in "C:\pilgrim\pilsav" and boot the game it populates the folder with default.dia, default.sav and list.ini. If I save a new game titled TEST, the folder populates with TEST.dia, TEST.lis, TEST.not and TEST.psa, and the list.ini remains empty. I'm not sure if my saves not ending in .sav like the default is a sign of something?
Any help at all would be so appreciated, the game really isn't playable without the ability to load saves! I have the game running as admin by default so I don't think it's a permissions issue but I could try reinstalling the game into a different folder.
Thanks!
