First post, by anighosh2026
Hi everyone,
I've been working on RetroSLIP, a Hayes-compatible SLIP dialer for DOS. It is designed to provide a simple way to establish SLIP networking on DOS systems using a modem/serial connection.
I've been testing it extensively in 86Box with MS-DOS 6.22, using the Standard Hayes-compatible Modem device and COM1. The resulting networking stack is:
RetroSLIP → SLIPPER → mTCP
I've successfully tested the connection with Arachne, including loading modern surviving websites such as Win3x.org.
I also tested MicroWeb. While MicroWeb can establish networking through the same stack, I encountered a Divide overflow while loading a page. This occurred with both COM1 and COM2, so it does not appear to be a COM2-specific problem. At this point I consider this a MicroWeb-related known issue, rather than a confirmed RetroSLIP problem.
Project: https://github.com/aghosh2020/retroslip
I'm posting this here because I thought it might be interesting to people working with DOS networking, vintage PCs, and emulation.
Screenshot
The attachment rslip-current-version.png is no longer available
The attachment 86Box_Zje1LsPxjY.png is no longer available
The attachment 86Box_kzdivk5WTZ.png is no longer available
The attachment arachne-dialer-setup.png is no longer available
The attachment arachne-86box-modem-settings.png is no longer available
Reply 1 of 5, by mbbrutman
A few suggestions for the code:
  • Do not assume that COM1, COM2, COM3 or COM4 are at those addresses. That is often wrong on the PCjr, a fairly common machine. You can provide default values, but allow the user some way to override them.
  • Look up the stricmp function and use it if your compiler supports it, or make your own. (It is a case insensitive string comparison.)
  • Don't program the UART yourself - use the built-in BIOS routines to open the port (set the divisors) and to read and write to it. UART divisor constants might be different depending on the machine - the PCjr is a good example of this. Nothing you are doing is performance sensitive so there is no reason not to use the BIOS.
  • You don't need 32 bit values to compute elapsed times when using BIOS timer ticks. 16 bit values are fine, and probably even 8 bit values work. Also, you should check for wrap-around no matter what size counters you use.
  • Values like PROGRAM_SHORT_NAME that are defined in a #define do not need to be printed with printf. You can do something like this: puts( PROGRAM_SHORT_NAME " text string here..." ); If you really want to do it correctly, use the printf but use argv[0] (the name of the program as given to the command shell) as the argument to printf.
  • Multiple line printfs with static text and be consolidated into a single printf or puts with one string that has embedded new lines. The string can even be split across multiple lines. See https://github.com/mbbrutman/mTCP/blob/dbb161 … /DHCP.CPP#L1039 for an example.
Reply 2 of 5, by jakethompson1
mbbrutman wrote on 2026-08-17, 22:17:
But the BIOS may require that DSR be asserted to communicate, which can be annoying if your null modem cable doesn't have it wired (eg CD-DTR instead of DSR-DTR or both). I'm more familiar with this issue because it breaks ctty com1.
Reply 3 of 5, by mbbrutman
It seems like that is something that the DOS Mode command should have been able to override.
Anyway, the NULL modem cable looks like a valid exception to the rule. But not using the BIOS means you have to set the divisors yourself. It is probably a good middle ground to use the BIOS to initialize the ports, then use direct hardware writes to adjust the signal lines as needed.
Reply 4 of 5, by Jo22
Hi, how about using FOSSIL drivers for hardware abstraction?
https://en.wikipedia.org/wiki/FOSSIL
Reply 5 of 5, by anighosh2026
Another interesting compatibility test: RetroSLIP + EtherSLIP on an IBM PCjr (DOS 2.10).
The attachment 86Box_ZiUzexI6QC.png is no longer available
I got an unreleased development version of RetroSLIP working on an emulated IBM PCjr in 86Box.
I followed your suggestion and tried EtherSLIP with RetroSLIP, and it worked on the PCjr.
The PCjr is running IBM PC DOS 2.10, 8088 @ 4.77 MHz, 128 KB RAM, with the serial connection running at 9600 baud.
RetroSLIP supports two serial backends:
BIOS mode uses the BIOS Data Area to determine the COM port address and communicates through BIOS INT 14h. This is the default mode and was used for this PCjr test.
DIRECT UART mode bypasses the BIOS and directly programs the UART registers. It allows higher baud rates, including up to 115200 baud, when the hardware supports it. The UART base address can be explicitly specified with /DIRECT= (or /UART=).
The setup is:
RetroSLIP → Hayes-compatible modem → SLIP → EtherSLIP → mTCP → Internet
RetroSLIP correctly gets the PCjr's COM1 mapping from the BIOS:
COM1 / 02F8h / IRQ3 / 9600 baud
EtherSLIP was then explicitly configured as:
ETHERSL 0x60 3 0x2F8 9600
mTCP successfully reached Google and received 3 out of 4 ICMP replies, with approximately 122–146 ms response times.
So yes — an IBM PCjr running DOS 2.10 at 9600 baud can access the modern Internet through this setup. 😂
RetroSLIP v2.0.0 is still unreleased and under development; this is a compatibility test for now. :')
