First post, by MrTechnician
These are games and programs that I only ever seen working fully right in a single machine.
Prehistorik 2: the overworld's position flickers when scrolling. I first seen it in WinXP with pentium 3 computers, and I see it on my machine as well; there was a single msdos or freedos + particular TSR combination that made that part work right here, but I got it only once and cant remember it anymore. My guess is CPU load/timing? After all the clock is unlocked in this system, but I dont remember if I lowered it or not. The one part that is nearly guaranteed to have display problems is the blue menu for passwords and game difficulty; screen tearing, shaking, the letters drag with the background... That only worked right in some old computer I cant access anymore, not even dosbox seem to do this one right.
Kgen98: 16bit mode only worked in an old Compaq Deskpro Pentium 2 computer. Tried an older Pentium 1, a later Pentium 3, didnt work on either. No effect with nolfb, no effect with a tsr that reports vbe2 instead of vbe3. I wonder if has anything to do with an unsupported scanlines mode for some reason, but thats just an aside.
No$gba: it only worked in an old Compaq Deskpro Pentium 2, and not even at full speed. The pentium 3 system would display a broken black & white image at best, and on my current system... It outright SHUTS DOWN when trying to run any ROM. To be fair, the msdos version of this emulator always struck to me as unfinished even when working right; ingame menu is glitched, options menu displays at wrong text resolution, and so on.
I doubt theres any proper fix for these. Any other known difficult to run software or games?
Reply 1 of 18, by MrTechnician
Two more to the list (I cant edit my post for some reason)
Crystal Caves: Would only display straight lines in two old pentium 1s (or earlier if I remember correctly). Works fine on my system somehow
Mario & Luigi (fangame): old systems had a black screen, but I know the game itself didnt crash because it still played sound effects. It works on my system for some reason.
Reply 2 of 18, by RandomStranger
I never had issues with Prehistoryk 2. Played it on multiple systems and VMs. It's a problem specific to you, not the game.
Reply 3 of 18, by MrTechnician
Even the blue menus work right for you? Mind if ask your system specs?
Reply 4 of 18, by keenmaster486
Tyrian 2000. Good luck.
World's foremost 486 enjoyer.
Reply 5 of 18, by RetroPCCupboard
Midtown Madness has been very problematic for me. Most systems display random polygons everywhere
Reply 6 of 18, by dr_st
MrTechnician wrote on 2026-08-16, 18:15:
Prehistorik 2 is a finicky game, for sure, but I don't recall game-breaking scrolling issues being common. It certainly runs well in DOSBox, there may be some tearing, especially in these blue menus, but that seems normal for a DOS game intended for 70Hz being forced to a 60Hz LCD in an emulator.
I also recall it working fairly well on my K6-II system in pure DOS, after I disabled a couple of TSRs which would cause it lock up almost immediately after starting level 1.
Reply 7 of 18, by leileilol
MrTechnician wrote on 2026-08-16, 17:21:
Clean your computer, sounds like a heat problem. NO$GBA purely uses the CPU and it's intended for faster computers than a P2....
MrTechnician wrote on 2026-08-16, 17:35:
Press V at the main menu. Press Y.
A lot of these sounds like NTVDM bugs or an unspecified video card (possibly Rage Pro or nVidia Vanta) just breaking VGA stuff. These aren't rare only-works-on-rare-computer games.
long live PCem
Debian's fucked
Reply 8 of 18, by MrTechnician
keenmaster486 wrote on 2026-08-16, 19:42:
That works! By disabling cache and setting CPU speed to 60MHz with a tool. Really finnicky, I've found no way to run sbemu (both versions) or vsbhda on top of it yet. Graphically fine though, control works, there's probable slight input delay (IMO)...
dr_st wrote on 2026-08-16, 21:28:
Is it possible that 70Hz weren't common enough and/or I've been unlucky and getting systems that can't display at that refresh rate?
Reply 9 of 18, by leileilol
70hz is the standard rate of 320x200/640x400. If your monitor can't display that, there's going to be a lot of problems......
long live PCem
Debian's fucked
Reply 10 of 18, by keenmaster486
MrTechnician wrote on 2026-08-16, 22:07:
I have also found its setup utility to be particularly bad.
Reply 11 of 18, by MrTechnician
leileilol wrote on 2026-08-16, 22:03:
What if is a bug?... I know that the power system has a name, next time I'll try to find it and disable it from BIOS. To be honest I don't remember any other unexpected shutdowns from this system
No, the computers it happened at didn't even have WinXP, or any WinNT for that matter. For example, I have vivid memories of trying to run it under windows 95 in window mode, because it would just never display anything in raw DOS
Reply 12 of 18, by wbahnassi
Curse of Enchantia... very dependant on memory configuration.. Sometimes it wants EMM386, sometimes QEMM, sometimes nothing works.. It is very hard to run it even on period-correct machines. It just takes you to a black screen.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 13 of 18, by Errius
POD (1997) is incredibly fussy about hardware. I built an entire system just to play this one game (P200 MMX, Voodoo2, Windows 95C) and even so there are still graphical glitches on menu screen (does not affect game play though.)
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Reply 14 of 18, by BitWrangler
RetroPCCupboard wrote on 2026-08-16, 21:12:
I think it liked early 3D hardware. I have seen it running, though not super smoothly, on a system with P166 and S3 Virge. I had a (coverdisk?) demo for it running in software mode on a PII laptop years ago, then lost the demo.
Reply 15 of 18, by MrTechnician
I stand corrected about prehistorik 2. This monitor doesnt report EDID; system is UEFI, and I seen that this monitor always reports 60hz no matter what.
Curse of Enchantia works fine with HimemX + Jemm386.
Reply 16 of 18, by MrTechnician
To expand on EDID's issue (as I understand it), its a timing mismatch caused by the system falling back to 60hz as safe mode when EDID is missing, even while the running program wants 70Hz.
Reply 17 of 18, by gerry
very few that i encountered to be honest, i don't play enough perhaps to get this. I used to have problems with actual systems in the past, now it seems that if it doesnt just run on xp/7 then there's a patch or something that resolved it. DOS games used to be fussy, then dosbox solved most of that
Errius wrote on 2026-08-17, 03:52:
i played that on a P166 mxx with win 95 and it was fine, i have never tried on another system except once with gog version on win 7 - worked fine, but games wasn't as impressive as i recall 😀
that's interesting, i have played that on a couple of modest spec XP systems and found it always worked ok
Reply 18 of 18, by RetroPCCupboard
BitWrangler wrote on 2026-08-17, 04:05:
Yeah, I think you are right. I haven't tried it on my Pentium MMX / Voodoo 1 / S3 Verge PC. I just assumed that machine would be too slow for it.
