Monitor scaling issue
First post, by Kouwes
I have a WinXP rig with a GTX680 and got a ViewSonic VX2025wm monitor because I like it‘s design.
Problem is, the image won’t scale when connected on DVI. Well, I didn’t try a VGA cable because I want DVI but it should work I guess.
Native monitor resolution is 1680x1050, which works but the image is larger than the screen. You can scroll up/down and left/right with the mouse though.
I didn’t find any setting on the monitor OSD, only setting to adjust should be found in the nvidea control panel - that insists my monitor is actually a TV so I can’t change any settings in the menu.
Also this message keeps popping up in the OSD saying I should change my display resolution to 1680x1050 - but is already set.
I tried changing DVI on the GPU but that did not solve the problem.
I’m using nvidia driver version 368.81 by the way.
Any thoughts?
Reply 1 of 2, by Barley
Try 355.98 or even earlier. The general consensus is that Windows XP support got progressively worse in these later drivers. Your GTX680 was released in 2012, so you have a lot more leeway in older driver support than those of us trying to use GTX980Ti's and such.
Reply 2 of 2, by Kouwes
I will give that a try, thanks!
Downloaded 337.88 and also 306.33, just in case the first one doesn’t work.
