First post, by NorsteinB
I recently got this sound card from Terratec, the Maestro 32, not to be confused with the 32/96 or the TT-929, and noticed that none of the usual sites like theretroweb know it.
Now under its FCC ID you find a bunch of Gallant SC-6000 cards, but none of them have a line out in form of a red and white cinch plug, and all of their PCBs look noticeably different.
There also was a Terratec Dream GSWAVE wavetable daughterboard bundled with the card, which features unlicensed Roland SC-88 samples that Terratec got in legal trouble over, as well as a decent FX processor.
The Speaker Out coupling caps are pretty much the best you got back then (470uF 16V) but Speaker Out will probably sound shit anyway because the amp is actually two LM386, one for each channel.
Thankfully, the line out is not routed through those and goes directly to the red and white connectors, so it should sound a lot better.
This sohuld be compatible to Sound Blaster Pro, Windows Sound System (Impulse Tracker ho!) and it features a genuine Yamaha OPL3 (YMF 262-M, so AdLib Tracker will also sound great), I'm really looking forward to installing it.
I hope the driver floppies that came with it still work, because I could not find the driver anywhere, not even on Terratec/Ultron's page or archived versions of their FTP directory.
Sadly, that 32 Mbit wavetable daughterboard I mentioned is shittyfluting melodies, a really good example is when the bridge of Duke Nukem 3D - Grabbag starts, I suspect this is due to a 50 MHz oscillator failing.
Here are pictures of the card and a short video of the failing wavetable.
The attachment terratec maestro 32.jpg is no longer available
The attachment terratec maestro 32 ymf262m.jpg is no longer available
The attachment terratec maestro 32 gallant sc6000.jpeg is no longer available
https://www.youtube.com/watch?v=M8SKjgUcXuY
Reply 1 of 14, by gerwin
NorsteinB wrote on 2026-08-28, 21:59:
Pretty sure I have the same card and the GSWave daughterboard. I also have the drivers on disk. So in case one of your floppies is bad, you can poke me.
Reply 2 of 14, by Ozzuneoj
Very interesting card!
Can you post pictures of whatever you got with the card? Box, manual, disks, daughterboard, etc.
I found the card listed on this page, but there is no mention of it being a Tarratec product. Just a Gallant SC-6000.
https://retrosoundcards.wordpress.com/gallant … allant-sc-8000/
Reply 3 of 14, by gerwin
gerwin wrote on 2026-08-28, 23:03:
I checked, but it is not the same. I have one like this:
https://amoretro.de/2011/06/terratec-maestro-16.html
Same ASC-9308 chipset though, but branded "CompuMedia" instead of "Gallant".
Reply 4 of 14, by NorsteinB
Ozzuneoj wrote on 2026-08-29, 00:10:
Very interesting card! […]
Can do in a few hours, I got a lot of original floppies, the box, the manual and a sort of poster of Terratec products of the time.
Reply 5 of 14, by NorsteinB
I got around to making them:
The attachment Terratec Maestro 32 Box content.jpg is no longer available
The attachment Terratec Maestro 32 Dream GSWAVE module front.jpg is no longer available
The attachment Terratec Maestro 32 Box front.jpg is no longer available
The attachment Terratec Maestro 32 Box back.jpg is no longer available
So 9 floppies, a wavetable daughterboard, 2 identical posters ( I only put one in the shot), normal standoffs for the daughterboard & extra long standoffs plus a wavetable connector extension in case you want to mount the daughterboard on a card with high components on its PCB.
gerwin wrote on 2026-08-29, 00:24:
I checked, but it is not the same. I have one like this: https://amoretro.de/2011/06/terratec-maestro-16.html Same ASC-9308 chip […]
Could you listen to the official Duke 3D Grabbag GM version MIDI and tell me if your daughterboard also shittyflutes it like in the Youtube video I posted earlier? Because if so it is bugged, but if not I would attempt to repair mine.
Reply 6 of 14, by NorsteinB
And here are the short sides of the box and the back side of the wavetable daughterboard.
The attachment Terratec Maestro 32 Box left side.jpeg is no longer available
The attachment Terratec Maestro 32 Box right side.jpeg is no longer available
The attachment Terratec Maestro 32 Dream GSWAVE module back.jpeg is no longer available
It looks kinda like somebody duct taped it, but this is not tape at all, it is 100% even with with the rest of the PCB so either completely fused or painted.
Reply 7 of 14, by cyclone3d
Weird. Are you 100% sure that card originally went with those disks, manual and box?
I've run into a ton of hardware that was put into the box of the hardware when the original owner upgraded and then it ends up on eBay or other platform as what originally came in the box.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 8 of 14, by Ozzuneoj
NorsteinB wrote on 2026-08-29, 14:09:
I got around to making them: […]
Very cool! Thank you for posting the pictures. I don't believe that pictures of this set exist anywhere else online. At least not that I could find.
cyclone3d wrote on 2026-08-29, 15:19:
I was thinking the same thing, but if you look at the picture of the card on the poster it is definitely the same card... though it looks like they used a different DB for the photo. If not for that I would still be suspicious... but if the drivers work for it and the DB + extension and spare standoffs all fit properly, it all seems to be correct. It must just be a model that Terratec bought and stuck in their packaging without adding any of their own markings to it.
Definitely a rare card and an even rarer set to have with the box and accessories.
EDIT: Interesting side note... I can't find any wavetable daughterboards from the '90s that match the one shown attached to the card on the poster. The one the card actually came with is definitely a Terratec DREAM GSWAVE (search this page), but it doesn't match the poster. The distinguishing feature, of course, is that it seems to have a lot of components on the back (facing up). That's pretty unusual.
Reply 9 of 14, by NorsteinB
The box art even features a picture of the exact card, down to the cinch outs.
The attachment terratec poster 1.jpg is no longer available
The attachment terratec poster 2.jpg is no longer available
If you're talking about the Wave System Professional from this poster (a.k.a. SOWT-24), I have that one, too.
Aside from that shittyfluting thing it does, the samples themselves sound better on the Dream GSWAVE - because the FX processor is configured better. But they are the very same samples stolen from a Roland Sound Canvas. If you want pictures from the SOWT-24, I can make some.
Reply 10 of 14, by gerwin
[Could you listen to the official Duke 3D Grabbag GM version MIDI and tell me if your daughterboard also shittyflutes it like in the Youtube video I posted earlier? Because if so it is bugged, but if not I would attempt to repair mine.
Maybe you are running into this issue:
This GSWave DB has at its core the Dream SAM9203 chip. The predecessor of the usual SAM9233. SAM9203 is in some regards a slow chip, when certain midi events are scheduled too close together, the chip discards some of these events. In the attachment you can find two midi tracks, One showing this issue, and another where I delayed the "program change" events. The former messes up on SAM9203, the latter plays fine.
Reply 11 of 14, by gerwin
Terratec is known for variations in their pre-'96 sound card product line-up:
- Sound System Gold 16, usually OPTi based IIRC. Lots of variants of this one.
- Sound System Maestro 16 with 2MB wavetable DB
- Sound System Maestro 32 (supposedly the same card as Sound System Maestro 16, but with 4MB wavetable DB)
Then later they had a similar product line-up with /96 suffix, and these are more consistent.
Reply 12 of 14, by NorsteinB
I mean I can try this in a bit, but it would be a a great help if you could just run the GM (not GS) MIDI file from http://leejacksonaudio.lbjackson.com/GrabbagO … VersionMIDI.zip and tell me whether or not it shittyflutes for you from about 1 minute on. If not, my daughterboard is broken, if yes it is a property of the synth.
Reply 13 of 14, by gerwin
NorsteinB wrote on 2026-08-29, 16:30:
I get that, but I don't have it installed now. Maybe tomorrow...
Reply 14 of 14, by NorsteinB
My sound test rig suddenly has issues that are completely unrelated, but won't be solved tonight. God that's frustrating.
