First post, by bog_dan_ro
bog_dan_ro
Offline
Hello there,
Can someone who has a working Wildcat4 7110/7210 run Quake 2&3 benchmarks at 32-bit for 1920x1080, 1280x720, and 1024x768?
I'm using the following params for my benchmarks:
./ioquake3 +set cl_renderer opengl1 +set timedemo 1 \+set r_colorbits 32 +set r_texturebits 32 +set r_depthbits 24 \+set r_picmip 0 +set r_vertexLight 0 +set r_lodbias 0 +set r_subdivisions 4 \+set r_detailtextures 1 +set r_fastsky 0 +set com_maxfps 0 \+set vm_cgame 0 +set vm_game 0 +set vm_ui 0 \+set nextdemo quit +demo four \+set s_initsound 0 +set r_mode -1 +set r_customwidth 1024 +set r_customheight 768 \+set r_fullscreen 1 +set r_ext_multitexture 0./quake2 +set vid_renderer gl1 +set s_initsound 0 +set r_mode -1 \+set r_customwidth 1280 +set r_customheight 720 +set vid_fullscreen 1 \+set timedemo 1 +demomap demo1.dm2
I need them to compare against the reverse-engineered driver that I created for my sun blade 2500 red.
Right now I'm getting quite low FPS (Q3: ~30 FPS 1024x768 and Q2: ~25 FPS 1024x768)
Many thanks in advance!
P.S. Yes, I'm going to release it once I'm happy with it 😉.
