Thank you. I have no experience of these slot loaders, and was a bit surprised by how violent the load/eject mechanism is - as you can see it visibly flexes the top part of the metal enclosure, which I definitely didn't expect. It does appear to work fine otherwise, and makes no other untoward noise, so perhaps it's all good. That said, I just tried to burn a CD-ROM with it and while it seemed to work at first the burn failed once the drive sped up to maximum speed... Regarding your suggestion about lubricating the drive (I do have silicone oil to hand): is that a practical proposition on delicate device like this? I wouldn't hesitate to have a poke around in a regular 5 1/4" optical drive, but this one is tiny and due to being a slot loader surely much more complicated inside?
