Audio drops based on game camera
First post, by DustyShinigami
I've been aware of this for a while now, but I'm not sure if it's just the way a game is and how the audio is programmed, if there's some sound card setting I need to adjust, or if there's some sort of mod patch. I noticed it for the first time in Half-Life and then whilst I'm replaying Return to Castle Wolfenstein, it happens in that, too. Basically, if you're facing a certain direction, presumably the source of the audio, you hear a character's speech fine, but if you turn to face a different direction, even ever so slightly, the audio becomes much quieter, which makes it difficult to hear what's being said. It's worse during the tram ride in the original Half-Life as the tram is constantly moving different directions. You've basically got to face inside the tram rather than sitting back and watching the ride from the front. Even then I'm not sure if facing inside the tram is guaranteed to work.
It can't be the speaker setup as both retro PC and my main PC are using a 2.1 setup - 2 stereo speakers and a subwoofer. It wouldn't be much of an issue if a lot of these older games had a subtitles option, but a lot of them don't, unfortunately.
Has anyone else encountered this? Is it a case of having to deal with it or is it something that can be addressed? Thanks.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 1 of 46, by NeoG_
Check to make sure all of the settings are aligned - Windows speaker settings, sound card settings (Creative AudioHQ) and game all set to stereo. The effect is attributed to the game rendering positional audio to speakers that don't physically exist.
Reply 2 of 46, by DustyShinigami
NeoG_ wrote on 2026-09-04, 03:49:
Okay, thanks. I'll check when I next boot it up. I'm guessing though that everything is set to stereo, but I could have missed an option in the Creative options somewhere. Just seems a bit strange for them to render positional audio to speakers that don't exist, especially if everything is set to stereo.
OS: Windows 98 SE
Reply 3 of 46, by NeoG_
The other thing you can do is use a pair of earphones or similar to check if the missing sound is coming out of the black (rear) jack
Reply 4 of 46, by DustyShinigami
NeoG_ wrote on 2026-09-04, 10:52:
Hmm. None of my speakers appear to have a headphone jack and the sound card I'm using - the CT4670 - has four 3.5mm jacks (red, blue, green and black) and the speakers/subwoofer are plugged into the black.
Sound-Blaster-CT4670
OS: Windows 98 SE
Reply 5 of 46, by NeoG_
DustyShinigami wrote on 2026-09-04, 11:27:
Hmm. None of my speakers appear to have a headphone jack and the sound card I'm using - the CT4670 - has four 3.5mm jacks (red, […]
They should be plugged into the green (front), not black (rear). I imagine you had to mess around with the speaker setting to get sound to come out of the black output because it's the rear. Once the speakers are in the green output and the creative speaker selection is plain 2 speakers it should work normally.
Reply 6 of 46, by DustyShinigami
NeoG_ wrote on 2026-09-04, 13:33:
My mistake. Looks like they were already plugged into the green. Though the green rear, as in - the back of the sound card.
OS: Windows 98 SE
Reply 7 of 46, by NeoG_
It would still be good to know if you plug headphones into the black connector on the sound card, is the missing sound there
Did you get a chance to check the windows speaker setting and the audio HQ setting?
Reply 8 of 46, by DustyShinigami
NeoG_ wrote on 2026-09-06, 01:55:
I was going to mention the settings and started taking screen grabs of the various options, but became incredibly tired and couldn’t keep my eyes open any longer, so had to retire for the night. I’ll continue getting those later and post them here. I’ll also try plugging the headphones into the black connector, too.
OS: Windows 98 SE
Reply 9 of 46, by DustyShinigami
I thought I'd stumbled on the solution, but sadly not. For some reason the speaker set up was set to Surround Sound instead of Stereo. But alas, it didn't make any difference. Also, plugging the headphones into any of the sound card's ports doesn't do anything. I had to plug it into the right stereo speaker. Sadly, the same issue happens with headphones.
These are the only main audio controls of interest. Not sure what, if anything, would help:
OS: Windows 98 SE
Reply 10 of 46, by DustyShinigami
The attachment untitled6.png is no longer available
The attachment untitled7.png is no longer available
The attachment untitled8.png is no longer available
The attachment untitled9.png is no longer available
The attachment untitled10.png is no longer available
OS: Windows 98 SE
Reply 11 of 46, by DustyShinigami
The attachment untitled11.png is no longer available
The attachment untitled12.png is no longer available
The attachment untitled13.png is no longer available
The attachment untitled14.png is no longer available
The attachment untitled15.png is no longer available
OS: Windows 98 SE
Reply 12 of 46, by NeoG_
DustyShinigami wrote on 2026-09-07, 00:10:
Normally that would have been the culprit, the other common one is AudioHQ being set to 4 speakers. In the affected games, if there is a hardware acceleration option for audio (also sometimes shown as a DirectSound3D/EAX setting) does turning it off "fix" it?
Reply 13 of 46, by DustyShinigami
NeoG_ wrote on 2026-09-07, 00:47:
In Return to Castle Wolfenstein, sadly not. There’s barely anything to change apart from three audio sliders and audio sample rate. Not unless there’s a hidden option in a config file.
Half-Life does have an EAX option, I believe. I can’t remember if I tried changing that already or if it made a difference. I’ll have to give it another go.
OS: Windows 98 SE
Reply 14 of 46, by DustyShinigami
I have come across these patches and mods for RTCW that aim to improve the audio and music quality, so I'll give these a try and see if there's any improvement.
https://github.com/iortcw/iortcw
https://www.moddb.com/games/return-to-castle- … usic-soundtrack
OS: Windows 98 SE
Reply 15 of 46, by DustyShinigami
Yeah, disabling EAX/DirectSound3D doesn’t help, sadly. Also, I noticed SFX drop out as well as voices.
With RTCW, the mod doesn’t work under 98, which is no surprise, so going to try it under XP. I need to find a patch for it first though. Running RTCW normally under XP produces the same issue with speech, so it’s not exclusive to an operating system or anything.
OS: Windows 98 SE
Reply 16 of 46, by NeoG_
Any chance of getting a video of it happening recorded on your phone?
Reply 17 of 46, by DustyShinigami
NeoG_ wrote on 2026-09-08, 00:33:
My phone is shockingly bad. Couldn't even hear the audio after recording, so I recorded using my handicam. I've recorded both RTCW and Half-Life.
You should hopefully be able to download them from here: https://gofile.io/d/hg0aO2LU
OS: Windows 98 SE
Reply 18 of 46, by DustyShinigami
I'm wondering - could this be a sound card related issue? I mean, the sound card I'm using in this second retro PC is a Sound Blaster Live! Value from 1998. Maybe there's some drawback when dealing with spatial audio in later 3D games...?
OS: Windows 98 SE
Reply 19 of 46, by NeoG_
The videos are pretty much what I had imagined, no revelations there unfortunately
No problem with the card that I know of, I have a sound blaster live value in my K6-2+ system and it didn't exhibit any of these issues. I can force it to have the issue by setting windows and the sound card to 4 channel and only have 2 speakers plugged in.
Only other thing I can think of is that it's driver related
