First post, by DW12
Hi, I own 3 cards that are based around same chips - the CompuMedia ASC-9408A and the Crystal CS4231A-KL. I've got 2 Gallant SC-6600 V2.0 cards:
The attachment IMG_20260904_233253_MP.jpg is no longer available
And a Gallant SC-7000 V2.0:
The attachment IMG_20260904_233400_MP.jpg is no longer available
I've tried to test them on 4 different boards (super socket 7 with VIA chipset, socket 7 AT board with Intel chipset and 2 slot 1 boards, one with VIA and one with 440BX chipset) and none of them are detected as a PNP device on the POST screen, which of course leads to them not being recognized in DOS/Windows. Am I missing something or it's really bad luck and all 3 of these sound cards are defective? The second SC-6600 V.2.0 (not the one in the picture above) looks to be in pristine condition, I don't think that there is anything wrong with them physically. I've checked the voltage on voltage regulators that are in top right corner on all of these cards and all 3 regulators seem to work fine. Do anyone have an idea what to try next? I'm mostly interested in getting the SC-7000 to work, as it has OPL4 onboard.
Reply 1 of 5, by gerwin
DW12 wrote on 2026-09-04, 21:59:
I have a similar card:
https://amoretro.de/2011/06/terratec-maestro-16.html
That card worked with the DOS drivers, when I tested it.
Have you tried the DOS drivers, in case the card is not PnP at all?
Reply 2 of 5, by DW12
Well, a thought that these cards may not be PnP crossed my mind. I've only tried a generic CS423X DOS driver and that didn't work. The other thing is it seems to be hard to find drivers for the C-Media ASC-9408A variants of sound cards, even now googling "Terratec Maestro 16 driver" got me only links for Opti drivers. I see there is a video on "Karl's IT Retro" website about Terratec Maestro 16 with C-Media chip (https://www.karlsitretro.com/terratec-maestro-16-review/). I will check drivers linked there and report back.
Reply 3 of 5, by gerwin
DW12 wrote on 2026-09-05, 20:17:
That Crystal Codec chip has no driver and does not need one.
As for Maestro 16 (also sold as Maestro 32 with 4MB Wavetable addon), here are the drivers I had stored:
https://www.transferxl.com/download/08vgryH0ZV3C2j
Also added similar Gallant SC-6000 drivers.
Edit, this may be more useful:
Gallant SC-6600 rev 2.0
Also:
Request for driver Gallant SC-7000 ver 2.0
And:
https://archive.org/details/soundcarddrivergallantSC6600
Reply 4 of 5, by DW12
Ok, so I ran the SC6600V2 driver installer in Windows 3.1, that added a initialization line to CONFIG.SYS and after reboot the SC-6600 started to work. Then I swapped the card to SC-7000 and got an IRQ initialization error while booting to DOS. I also tried running a CF card with Windows 98SE installation, I went through a process of scanning the system for non-PnP devices and Windows detected a gameport and a Sound Blaster Pro compatible device, however couldn't initilize the card properly. At least that tells me that the card is trying to work. I will try Windows 95 with some different drivers, maybe that will be more appropriate for this card.
Reply 5 of 5, by gerwin
DW12 wrote on 2026-09-07, 19:05:
.., that added a initialization line to CONFIG.SYS and after reboot the SC-6600 started to work.
Good to hear you got some progress there.
All these DOS driver packages seem to have a Sound.sys file as their core. Last one being 4.982 Bytes / Dated 14-08-1995.
Can also load it from the command line instead of Config.sys, with the devload utility:
devload C:\WINDOWS\SYSTEM\sound.sys /I:7/D:1/MIRQ:5/G:1/CDT:0/CDP:230/SSP:530
