First post, by RetroWolf92
RetroWolf92
Offline
Been trying to get into Blood again recently, and remembered it has FMV cutscenes. I can't get them to play on OUW, though. I tried first from the CD, even with the paths set right in BLOOD.INI, the intro stuff didn't load at all.
1.0 loads the cutscenes, but they move really slowly. I also tried copying the cutscenes over to the hard disk, still the issue isn't corrected.
I should mention this is on the Dell Dimension L566cx using SBEMU with the experimental VDPMI build. Strangely this doesn't happen with the last stable build.
The other difference is that the stable SBEMU runs using JemmEx, whereas the VDPMI build I have to use HiMemX. Does that make it a memory issue?
Any advice is appreciated.
