First post, by ekkiller
Hi everyone,
I'm currently trying to repair a Roland SC-88 Pro with a hardware issue and I'm hoping someone here might be able to point me in the right direction.
The problem:
· The unit receives MIDI data and appears to play, but the audio output is just crackling/scratching noise.
· The noise also occurs when pressing the front panel buttons (e.g., VOLUME/PREVIEW), so it seems to be an analog audio stage or power supply issue rather than a digital/MIDI reception problem.
I've opened it up and I'm focusing on the power supply and audio board.
What I'm looking for:
· A service manual or schematic diagram for the SC-88 Pro would be extremely helpful for tracing the power rails and audio path, and for identifying the correct capacitor values and positions.
· If anyone has a PDF copy or knows a reliable source where I can find one, I would be very grateful.
Any troubleshooting tips from those who have dealt with similar noise issues on these old Roland units are also more than welcome!
Thanks in advance for your time and help.
144KM……
Reply 1 of 14, by TheMLGladiator
High-quality one linked on this page: https://www.synfo.nl/pages/servicemanuals.html. Just search for 'SC-88PRO' without the quotes.
For troubleshooting, did you make sure that the transformer is correctly wired for your region? If yours is imported from Japan like mine the internal transformer needs to be rewired from the 100V used in Japan.
Reply 2 of 14, by ekkiller
TheMLGladiator wrote on 2026-09-08, 11:21:
Thank you so much for the link – that's exactly what I needed. I've downloaded the service manual and the schematics are clear enough to start tracing the power rails and audio path.
I really appreciate you taking the time to dig that up.
I'll report back once I've made some progress on the repair.
Thanks again!
144KM……
Reply 3 of 14, by ekkiller
First of all, thanks again to those who helped with the service manual link – it's been very useful.
I'm currently troubleshooting my Roland SC-88 Pro, now I've hit a wall. I managed to get into the test mode and ran the Memory Test – unfortunately, it came back as NG.
What I'm trying to figure out:
· Could the Memory Test NG be a direct consequence of the power supply issues (ripple, unstable voltage) rather than a dead RAM chip?
· Or is it more likely that the RAM chip itself has failed and needs replacement?
My current plan:
1. Recap the power supply board first (replace all suspect electrolytic caps and clean up the old glue).
2. Check for corrosion or bad solder joints around the RAM chips on the main board.
3. Retest and see if the Memory Test passes.
Before I dive in, I'd really appreciate any advice from those who have dealt with similar issues on these old Roland units. Specifically:
· Has anyone seen Memory Test NG clear up after a recap?
· Are there any common points of failure (e.g., specific capacitors, voltage rails, or RAM chip types) I should pay extra attention to?
Now I have the service manual and schematics, so I can trace things if needed. Just looking for some real-world experience to guide my next steps.
Thanks in advance!
144KM……
Reply 4 of 14, by ekkiller
Photos
file.php?mode=view&id=248823
144KM……
Reply 5 of 14, by ekkiller
Hi everyone,
Quick update – I spent some time going through the service manual more carefully, and I think I've finally pinned down the root cause.
When I run the Memory Test in diagnostic mode, the "C" indicator on the front panel flashes. According to the service manual, this points to a Wave ROM checksum error – specifically, IC22 on the main board is failing the verification.
This makes perfect sense given the symptoms: crackling audio output (garbage data being read from the waveform ROM), and the Memory Test coming back as NG.
I've located the chip on the board and noted the markings:
· Roland P/N: RO1124778
· Part No.: D23C32000-519
file.php?mode=view&id=248860
From what I can tell, this appears to be a mask ROM, which means I can't simply reflash it with a standard programmer.
My questions now are:
1. Before I source a replacement, is there anything else I should check? Could a bad solder joint, broken trace, or power supply issue cause the checksum to fail? Or is it almost certainly the chip itself?
2. For replacement options – is my best bet to search for a used pull (e.g., "Roland RO1124778" or "SC-88 PRO Wave ROM") on eBay or similar? Or is there a known-compatible EPROM substitute (e.g., 27C040) that I can program with a dumped ROM image, assuming I can find one?
3. If I go with a used pull, is it a straight swap, or does anything need to be recalibrated afterward?
I'm comfortable with soldering and basic board work – just need a bit of guidance before I commit to a course of action.
Thanks again for all the help so far – I really appreciate it!
144KM……
Reply 6 of 14, by ekkiller
Attach a photo of the machine nameplate.
file.php?mode=view&id=248861
144KM……
Reply 7 of 14, by TheMobRules
Not sure about the SC-88 Pro, but at least on the regular SC-88 the SMD electrolytic capacitors on the main board are a known point of failure and should always be replaced. In many cases their leakage corrodes traces, which can cause problems like the one your experiencing.
Could you attach a picture of the board with a close up on the caps?
Reply 8 of 14, by ekkiller
TheMobRules wrote on 2026-09-09, 05:22:
There is slight corrosion near the battery (CR2032) of the PCB
144KM……
Reply 9 of 14, by ekkiller
I measured the power supply voltage, and both +-12V and 5V are normal
144KM……
Reply 10 of 14, by zwrr
Please first rule out the following possibilities:
1. Are any chip pins loose?
2. Are there any leaking capacitors?
3. Is there any corrosion or breakage in the circuitry?
If you confirm there are no issues there, I would focus my attention on the SRAM or DRAM chips—specifically IC17, IC18, IC30, IC31, and IC32 (especially the SRAM). I once repaired two SC-55 units that played MIDI with the correct tempo, but the instrument sounds and pitches were completely garbled; after a long period of troubleshooting, I finally replaced the SRAM chips, and everything returned to normal.
It is easy to find replacements with identical specifications for these SRAM and DRAM chips, and the replacement process is straightforward if you have a hot air gun—so it might be worth giving that a try.
SBC1: Cyrix 5x86-120, HS-5x86HVGA, 16MB EDO, GD54M30, SB Pro II, HardMPU-wt
SBC2: VIA C3-800, PCISA-C800, 128MB SDRAM, Savage4 Pro, SB AWE64 Gold
SBC3: Tualatin-S 1.4G, PCI-6872, 256MB SDRAM, FX5200 PCI, Voodoo2 SLI, SB Live
Reply 11 of 14, by ekkiller
zwrr wrote on 2026-09-09, 07:53:
Please first rule out the following possibilities: 1. Are any chip pins loose? 2. Are there any leaking capacitors? 3. Is there […]
Thanks a lot for the detailed suggestions – I really appreciate you taking the time to write that up.
I've gone through the checklist you mentioned and here's what I found:
1. Chip pins loose? – No, all pins on IC22 and surrounding chips appear to be firmly soldered. No visible cracks or cold joints.
2. Leaking capacitors? – I've inspected the board carefully and didn't find any bulging or leaking caps. The power supply caps look clean as well.
3. Corrosion or broken traces? – There is minor corrosion on some areas of the main board, but I haven't found any open traces so far. I plan to clean it up properly and recheck with a multimeter just to be sure.
That said, your experience with the SC-55 is very interesting – especially the part about garbled sounds being caused by SRAM failure rather than the Wave ROM itself. My service manual points to IC22 (Wave ROM) when the "C" flashes during the memory test, but I'm open to the possibility that the SRAM/DRAM chips could be the real culprit.
You mentioned IC17, IC18, IC30, IC31, and IC32 – I'll take a closer look at those and see if I can test or replace them if needed. Before I go down that road, though:
· Is there any way to distinguish between a Wave ROM failure and an SRAM failure based on symptoms or test mode behavior, besides what the manual says?
· If I do end up replacing the SRAM/DRAM chips, do they need to be pre-programmed, or are they standard off-the-shelf parts that just hold runtime data?
Thanks again for the insight – this gives me a lot to work with!
144KM……
Reply 12 of 14, by zwrr
ekkiller wrote on 2026-09-09, 08:17:
Thanks a lot for the detailed suggestions – I really appreciate you taking the time to write that up. […]
DRAM and SRAM do not store data permanently, nor do they require programming; these types of chips are essentially the same as the system memory and cache chips found on computer motherboards.
As for the Wave ROMs, I assigned them a lower priority because—being mask ROMs—they typically have very low failure rates.
In the case of the SC-55 I mentioned earlier, the onboard SRM2A256SLM10 chips were faulty; these were 100ns chips, and the unit functioned correctly after I replaced them with 70ns SRM2A256SLM70 chips.
The reason I considered replacing the SRAM was that I had already exhausted all other options—including transferring all the Roland ICs and Wave ROM chips from a fully functional SC-55, which still didn't solve the problem. Replacing the SRAM was the last resort, and fortunately, it resolved the issue.
Reply 13 of 14, by TheMobRules
Looks like you have bad SMD capacitors as expected. For example, take a look at the cap on the lower right corner on the picture: notice the pads are dull and corroded, it has even affected the ground pad in the corner with the mounting hole.
I’d replace all the SMD electrolytics while also making sure that no traces have been affected.
Reply 14 of 14, by Kahenraz
Roland used some kind of adhesive on the large capacitors in many of these synthesizers that have started to decompose and eat away at traces on these boards. Although I don't see that from your photos, it did some serious damage to my SC-55mkII.
PCB destroying adhesive found in my Roland Sound Canvas SC-55mkII (inspect your synthesizer!)
Probably unrelated, but the solder that connects the RCA jacks to the board is also another common point of failure due to stress fractures. May as well do it now as preventative maintenance while it's open, since it's an easy fix with some fresh solder.
