First post, by fragment_
i have a serius problem, i finally succeded installing the sb16 drivers for dos and windows (i have an ac97 onboard) but i have a prob in win31w. It plays wave files but broken. i tried changing dma,irqs (both in dfend and system.ini) etc but nothing!
does anyone had the same prob to help me? 😒
Reply 1 of 5, by `Moe`
Please explain "broken" with a little more detail.
Reply 2 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
dosbox doesn't emulate an ac97 ?
Water flows down the stream
Reply 3 of 5, by fragment_
broken i mean it crashes like playing a scratched cd. . . dosbox emulates ac97 but windows 3.1 needs drivers to support sound.
Reply 4 of 5, by wd
Rank DOSBox Author
DOSBox Author
No it doesn't emulate an ac97.
The emulated soundcard is a standard SB 220/7/1
Reply 5 of 5, by `Moe`
Well, as he said, he tried to install the sb16 drivers.
If your sound is scratchy, try lowering cycles or switching to dynamic core. The usual "performance tweaking" tips apply - look at the FAQ.
