First post, by stanwebber
i'm a little unclear on where to ask this. the system in question is a gigabyte ga-ep45-ud3p (p45/ich10) so i guess it does still qualify as retro status...
there is a lot of undiscerable slop online concerning win10 & midi that i've ignored over the years. i never thought i would ever have to deal with this as i run anything requiring winxp or later in wine/alsa, but now i'm forced to.
all i want is a single virtual midi loopback cable. i've installed both loopmidi and loopbe1 and, while neither report any errors, neither show up as a midi in/out target. the applications i'm using are fsmp and hairless midi serial bridge. the only midi target i ever see is microsoft gs wavetable synth. what is broken? is this some stupid permissions thing?
a few notes on my win10 22h2 system:
- 64bit, uefi, windows driver signing disabled
- windows defender stripped out (https://github.com/ionuttbara/windows-defender-remover)
- no windows midi service (whatever that is) in services.msc
Reply 1 of 4, by ott
  • The loopMIDI works perfectly, but it doesn't create MIDI ports by default. Click "+" button at the bottom to add port.
  • Windows MIDI Services is part of Windows 11 and adds support for the new MIDI 2.0 specs, so you don't need it.
Reply 2 of 4, by stanwebber
yeah, that wasn't it. i created 2 midi ports multiple times. even tried it with an administrator account.
Reply 3 of 4, by ott
I don't have Serial port devices, but it looks like everything is working, both programs are sending/receiving MIDI data via loopMIDI.
Tested on regular Windows 10 Pro 22H2 x64, administrator privileges were not used.
Reply 4 of 4, by stanwebber
virtual loopback midi ports do not fricken show up in an rdp session: moonlight/steam link is required (i assume vnc would work as well). asinine microsoft bs.
