First post, by TheHalfinStream
Hello everyone!
I have built a frankenstien WIN98 SE pc to play The Elder Scrolls Adventures: Redguard, because I am a mentally adjusted and sane individual 😜
Unfortunately I have been running into an annoying sound issue in DOS mode games within Windows 98 SE.
In DOS games run from Windows (e.g. Redguard), some speech lines and sound effects crackle. The same sample crackles on some playbacks and is clean on others. In SB Pro mode it turns into a more clicking-like sound instead.
I have been going insane trying to adjust my settings in-game, in os, in system.ini, autoexec.bat, config.sys, etc, to no avail.
My specs:
Voodoo 3 2000 PCI
512mb DDR400 ram
Intel Celeron 2.4ghz (I can limit the speed with CPUSPD, but it didn't seem to help)
Premio Intel 865G (865GM2) motherboard
Soundblaster Live 5.1 SB0100 (also tried SB0220) (Using Joseph_Joestar's Driver [OUTDATED] Installing Windows 9x and DOS drivers on Sound Blaster Live! cards (version 3.1))
I've spent weeks of my life on this issue, please save me.
Also, for your enjoyment, Redguard running better than you have ever seen it: https://youtu.be/3i2x2ZiON4E?si=IhanDNMuii8_mQhq
Thanks in advance!
