First post, by Virtue
Hi, I'm looking for a MHZ display, it has to be specifically a full 3 digit one as my PC is 550Mhz, I was literally 20 minutes too late for one on ebay 🙁 Willing to buy for a good price.
I live in the UK if that helps at all?
Picture of the one I was gonna buy for reference. I don't suppose one of you actually bought it did you? 😅 I'm willing to pay decent money 🤣.
Reply 5 of 16, by DaveDDS
Super easy to make one for one speed, more work but quite do-able for two.
The more speeds the more work (the more digits in common the easier)
Just need some 7-seg displays and a handful of diodes & resistors!
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 6 of 16, by BitWrangler
If you suck at figuring it out on a standard 3 digit part, wire all the anodes together through an orange orange brown 1/2 watt resistor, and sharpie out the segments you don't want 🤣
Edit: (Unless it's a common anode pull down model then do the cathodes instead)
Reply 7 of 16, by Virtue
Why doesnt anyone sell modern reproductions of these? They would be in high demand I think!
Reply 8 of 16, by Aui
- well the shop mentioned above does !
I dont think this assembly works with AT style cases unfortunately!
- its for the drive bay - why wouldnt it work ?
Sadly doesnt ship to the UK 🙁
- the shipping policy doesnt say anything about not shipping to the UK?
Reply 9 of 16, by darry
Seven segment displays are common on alarm clocks and alarm clocks are common at thrift stores, at least where I live. Old TV settop cable/satellite boxes are another source.
With some plexiglass, and a bit of dremeling, it should be possible to make something decently functional without needing to source any parts beyond what is already in the seven segment donor device or common at thrift shop.
Someone should write an instructable for this.
Note: Care must taken to avoid electrical shocks while doing powered on tinkering with any device with an exposed PSU (once the cover is off) that runs off of mains current.
Reply 10 of 16, by BitWrangler
If you've got a 1200 mhz cpu, just take the entire timer board out of a VCR and leave it un-set 🤣
Reply 11 of 16, by darry
BitWrangler wrote on 2026-11-05, 23:10:
Bonus : It flashes.
In all seriousness, 7-segment donor hardware is practically everywhere.
Reply 12 of 16, by Virtue
Aui wrote on 2026-11-05, 21:18:
- well the shop mentioned above does ! […]
They're only mountable in the 3.5" bay, im using both up.
And the listing has ended. In the description it said cannot ship to the UK.
Reply 13 of 16, by Aui
Im not refering to the auction listing , but the serdashop display. 5 inch drive bay variant is available.
Reply 14 of 16, by zapbuzz
I like that one 🤣
Reply 15 of 16, by Virtue
Its ok guys I managed to find another one 😀 No instructions or pin-out though, would I run the risk of blowing it up if I accidentally plugged the 5v into the wrong pins? I'm guessing so...
Reply 16 of 16, by darry
Virtue wrote on 2026-11-09, 22:40:
In the first photo you posted the 7-segment module that is soldered onto aPCB seems to be made by Ledtech, but the part number is unreadable. You might be able to find a datasheet. If you can, that will at least tell you which are the the VCC and ground pins AND how to configure the jumpers or DIP switches on the back to display the value you want (some putzing around with a multimeter in continuity mode will probably be required).
