First post, by keenmaster486
I have a lot of laptops, and even though I'm planning on paring my collection down to less than 10, probably about 5ish machines in active service at any one time, I still would like to come up with some method of storing them that isn't just stacking them all up on the floor.
I could lay them upright like books on a shelf in the closet. I've seen that done before. Maybe I'll do that with the ones I'm not currently using.
But I have this idea in my head of a set of shelves with chargers plugged into power strips on the back so the laptops can sit and charge while I'm not using them. A kind of "shelving unit docking station".
Has anyone done something similar to this, or does anyone have a better idea?
World's foremost 486 enjoyer.
Reply 1 of 6, by Jo22
Hi, yes I do have a few vintage laptops. 80286, 486, Pentium MMX, Pentium III..
Although to me it's still hard to grasp that the last one is "vintage".
After all, it can run both Windows 98 and XP no problem.
Edit: Storage, okay. Cardboard boxes and notebook bags.
Reply 2 of 6, by spunky_h0rn
I have them upright in bins. I keep any accessories like the power supply in a separate, smaller bin, everything tagged with what it goes with. I think this keeps the least strain on the screens or chassis.
But, I've only got about 10, with 2 in use most of the time. If you have a ton, that might be too space inefficient!
GA-M61SME-S2 + Athlon 64 x2 4400+ + 2GB DDR2-800 + ATi 3870
GA-6BXC + Pentium II 300 + 512MB PC-133 + nVidia TNT
GA-686BX + Pentium III 550 + 256MB PC-133 + nVidia TNT2 M64
Soon -> Socket A, Socket 7
Reply 3 of 6, by gerry
i either leave them in a laptop bag, if they came in one, or place them flat,stacked but only 3-4 max. I have maybe 10 laptops in total, perhaps a little less i'm sure i let some go, you can tell i dont use vintage laptops much..
Reply 4 of 6, by Unknown_K
I just use metal or plastic shelving and stack them 4 deep or so for the older units (you don't want too much weight on the bottom ones). Some old laptop rubber feet turn to goo so you can get them stuck together. Newer models without rubber coatings (common on old ThinkPads) get put into storage bins and put under the bed. Power bricks go into their own storage bins.
I have quite a few laptops.
Reply 5 of 6, by momaka
Stack vertically, in a cardboard box.
It will keep the strain off of the rubber feet and screen assembly. Also looks cleaner and is easier to store / move the entire box, and you can take whichever laptop you need right away (vs. when the laptops are stored horizontally and you need to move the entire stack, if say, you need to get to the bottom laptop). The power adapters and cords can also be placed in the same box if there is space on the side where the laptops are or the adapters can be placed in a separate box... whichever works.
I have about 20-ish old Pentium II Dell Latitude stored this way. Think I've had them stored like that for 15 years now.
(On a side note to myself... I probably should sell them :\ ).
keenmaster486 wrote on 2026-11-09, 16:58:
I would advise against that.
A laptop that is always plugged in and keeping the battery charged to near max ruins the batteries quicker. It's best to store Lithium batteries with about 20-50% charge. Now if the laptop's BIOS has an option to stop charging at a certain percentage, then you could set that to a much lower target and keep them plugged in. But most laptop BIOSes don't have that, so probably not worth pursuing. Also, it's a waste of power IMO (even though small) to keep laptops charged that you aren't using actively.
Reply 6 of 6, by Intel486dx33
I store them i my garage in cardboard boxes or plastic tubs
On wire rack shelves .
But I remove the batteries first.
No one wants a leaking battery to destroy your computers .
My wire racks have wheels so I can wheel the carts around.
These laptops get heavy once you start to stack them up.
I use to buy broken and not working laptops from
eBay looking for the perfect retro gaming laptop
Setup but now they have gotten expensive
And supply is low so I don’t buy them anymore.
