First post, by GameFreak
Hello everyone, I have been trying over the past few hours to run Final Fantasy VIII with my Terratec SixPack 5.1+ sound card (CS4630 chipset) and a header to Gameport/MIDI adapter. Which I have connected with my Yamaha PSR-550 Keyboard through MIDI. I confirmed the keyboard's up and running as MIDI files play through Cakebox.
It seems however that the game uses the DirectMusic API for sound and I am unable to select the DirectMusic Port in the game's config. The driver that I am using in Control Panel is called "SixPack 5.1+External MIDI", but in Dxdiag the "... SixPack 5.1+ DLS Synth" driver appears to be the only one supporting DLS. Neither drivers can be selectedas DirectMusic port, however, with only "Microsoft Synthesizer" showing up.
Is there a reasoning for none of the options showing up? And would there be an alternative so I could still use my PSR-550 with this game (with a different soundcard or additional wavetable extension card or something?
