Ok
1-dosbbox cfg.
fullscreen=false
fulldouble=false
fullfixed=true
fullresolution=800x600
output=opengl
hwscale=1.00
autolock=true
sensitivity=100
waitonerror=true
priority=normal
mapperfile=mapper.txt
language=
machine=vga
captures=capture
memsize=16
frameskip=0
aspect=false
scaler=none
core=dynamic
cycles=14000
cycleup=500
cycledown=20
nosound=false
rate=22050
blocksize=2048
prebuffer=10
mpu401=true
intelligent=true
device=default
config=
type=sb16
base=220
irq=7
dma=1
hdma=5
mixer=true
gus=true
rate=22050
base=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRASND
pcspeaker=true
pcrate=22050
tandyrate=22050
disney=true
directserial=false
comport=1
realport=COM1
defaultbps=1200
parity=N
bytesize=8
stopbit=1
# ipx -- Enable ipx over UDP/IP emulation.
mount c c:\riddle
mount j j:\ -t cdrom
2-riddle cfg.
M4_NET_USER=AHILTON
USERMODE=ADVANCED
INSTALL_TYPE=1
INSTALL_TYPE_NAME=MEDIUM
PROGRAMMERS_SIGN=PISCES
BACKGROUNDS_ON_HD=NO
CD_ROM_DRIVE=J:
RESOURCE_PATH=J:\RESOURCE\
HASH_TABLE=C:\RIDDLE\RIPLEY.HAS -->(dosboxdoesnt recognise this file)
MIDI_CARD=e016
MIDI_CARD_NAME=Sound Blaster 16
MIDI_TYPE=a002
MIDI_TYPE_NAME=FM (SB/Pro/16)
MIDI_PORT=220
DIGI_TYPE=e016
DIGI_CARD_NAME=Sound Blaster 16
DIGI_DMA=1
DIGI_ADDRESS=220
DIGI_IRQ=7
CIS=73766,347
3-full error message:error code: 0x0800
code found in:MASTER.M4E
offending exe:riddle.exe
source code index:..\fileio\F_SYSFIL.CCP:519
path to exe: C:\
Description:
hash file not found:C:\RIDDLEY\RIPLEY.HAS
