First post, by irontso
irontso
Offline
Hi,
I've just started using dosbox to play single player Warcraft 2 - works perfectly. I can start an IPX server on my desktp (winxp 2ghz 1gb ram etc..) but my laptop (almost identical) can't connect and dosbox says tunneling failed. Is this because my laptop and my desktop have the same ip address? Both are getting internet access from a cable modem split through a router.
I'm also using dosbox v0.63.
Thanks in advance!
