First post, by Mose
😒 Hello!
Can anyone help me! me Strike Commander CD-Version works in slowly
on Dosbox 0.63. I don't activate on the install Menue the VESA Local Bus.
My quest is how can i use in DosBox 0.63 the VESA Local Bus(VESA)
i tried the dgvesa but nothing happens.
How can help me? 😢
Cu
Mose
Reply 1 of 4, by eL_PuSHeR
VESA bios extensions don't have nothing to do with VESA Local Bus (VLB). The first ones are code to access SVGA modes and the last one is a type of bus like ISA, PCI, etc.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 4, by Mose
Ok,
But with which Command line and where activate i the VESA in the
DosBox 0.63, i don´t found it in the Forum.
Or is it usefull to use the CVS Bulid with the DosBox 0.63?
Cu Mose
Reply 3 of 4, by Lofty
CVS builds have better VESA support I believe, so you could try one of those. I'm not sure it will speed your game up though - indeed, VESA modes were often used for higher resolution, rather than more speed. Setting Core=Dynamic in dosbox.conf, and messing with cycles and frameksip is more likely to help.
Reply 4 of 4, by eL_PuSHeR
You don't need any command to activate VESA. It is used automatically when detected (if all goes well). Just grab a cvs version.
Intel i7 5960X
8 GB DDR4 (2100)
