First post, by Fez Boy
# AMD Athlon XP2200+ ~1.8GHz
# 512Mb RAM (64Mb used for Graphics card, so effectively 446Mb)
# ATI Radeon IGP 320M w/ 64Mb of above ram
# Conexant AMC Audio
# Windows XP Home edition SP2
# X-wing Collector's CD ROM
# Can run the game, but without sound. Any sound. I don't know how to get the sound.
# Sound mode used - Don't know
# Video mode (Software, OpenGL, Direct3D, or Glide, and resolution) - Don't know
# DOSbox 0.63
I bought this game a fair few years ago, back when I had an ancient Windows 95 machine that did actually have DOS as well. And it worked perfectly fine. However, now that I have a modern, shiny computer without DOS, but want to experience the heady fun of flying a spaceship, DOSbox is my only option. What I have done is put the CD in the drive (D:), opened DOSbox, typed mount d D:\ -t cdrom -usecd 0 -ioctl (as per instructions in the CDROM intro), and then run D:\bwing.exe, which I read was the right thing to do in the game compatibility index on the DOSbox site. The game loads up, but there isn't any sound. None at all. Obviously, I would like at least a vague semblance of sound.
I have searched the forum but found nothing of any pertinence or relevance.
Please help me.
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
did you runs some sort of install.exe or setup.exe to configure the game to use sound ?
Water flows down the stream
Reply 2 of 2, by Fez Boy
No. Should I have done? I'll give it a try.
Edit: WIN! Ran the installer, installed it on C: and now it all works fine. Thanks for making such a good emulator.
