First post, by moonbaby
I am trying to install Quest for Glory 1 and I cannot get it to install on windows, so I thought I could try to install on dosbox but I cannot get my a: drive to mount, so I have no way of installing it? How do I mount my a drive or is there another way to install this game without mounting my a: drive. I am not using a cd but disks, so maybe I have to do something different?
Reply 1 of 9, by HunterZ
What are the exact commands that you are trying to use to mount, and what is the exact problem/error that you're having?
Reply 2 of 9, by moonbaby
The commands it tells you when you type intro, but I cannot get my A: drive to mount.
Reply 3 of 9, by HunterZ
Please post the exact commands and the exact error message. I don't have access to a copy of DOSBox at work and can't vouch for what the intro message says.
Reply 4 of 9, by eL_PuSHeR
It should be something like mount a a:\ -t floppy
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 9, by Lofty
mount a: a:\ works for me...
Reply 6 of 9, by HunterZ
I don't think you can put a colon after the first 'a'.
Without knowing exactly what you're doing and exactly what you're seeing as a result, we can only guess at what might be going wrong.
Reply 7 of 9, by Lofty
HunterZ: You can (at least in the windows builds). I do all the time. 😀
Reply 8 of 9, by HunterZ
Thanks then, that's good to know.
Reply 9 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
it's a hack for those people who add that :
The official syntax is without though 😀
Water flows down the stream
