First post, by Macabre
Update : I got it working! Seems to be running just fine for now, with one odd crash during the emperor's cut scene at the beginning, but has not crashed during game. Haven't played extensively, so we'll see. Runs at a nice frame rate, full sound but a little slow if in full screen. I moved the directory from my D drive to C to get it to work. 😕
Windows 2000 :
'Daggerfall has encountered an internal error at 0.
The error reported was: Code 216 not found in
Exiting...'
Now, I'm running ykhwong's CVS build. The 'Code' in the error above changes depending on what land I want to be from. Here is what the background window says :
CONFIG:Loading settings from config file dosbox.conf
MIDI:Opened device:win32
Optimized Scalers disabled. Double buffer not supported
Warning: file creation failed: D:\GAMES\DAGGER\ARENA2\RUMOR.DAT
Reply 1 of 4, by eL_PuSHeR
Rank Moderator
Moderator
Get new DOSBox 0.65
PS. It seems you forgot to mount something or you mounted it the wrong way...
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 4, by Macabre
Same error, even when using new version of DOSBox. Arena plays just fine, and I have it mounted the same way. I've even tried copying the contents of the CD to the hard drive and directing the config file there, same error. Looks like I wasn't meant to play Daggerfall. 😢
