First post, by boyofdestiny
Hi, I hope this is the proper section, since everyone is talking about 0.65:) I also tried the current CVS, same errors.
Anyway, running ubuntu dapper (amd64), (let me know if you need more information), this is the output:
/usr/lib/gcc/x86_64-linux-gnu/4.0.3/../../../../lib64/crt1.o: In function `_start':../sysdeps/x86_64/elf/start.S:109: undefined reference to `main'
dosbox.o: In function `Normal_Loop':/home/safari/src/dosbox-0.65/src/dosbox.cpp:123: undefined reference to `PIC_RunQueue()'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:124: undefined reference to `cpudecoder'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:127: undefined reference to `CallBack_Handlers'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:134: undefined reference to `GFX_Events()'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:136: undefined reference to `TIMER_AddTick()'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:161: undefined reference to `CPU_CycleAuto'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:166: undefined reference to `CPU_CycleMax'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:168: undefined reference to `CPU_CycleMax'
dosbox.o: In function `DOSBOX_Init()':/home/safari/src/dosbox-0.65/src/dosbox.cpp:239: undefined reference to `Config::AddSection_prop(char const*, void (*)(Section*), bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:240: undefined reference to `Section_prop::Add_string(char const*, char*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:241: undefined reference to `Section_prop::Add_string(char const*, char*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:242: undefined reference to `Section_prop::Add_string(char const*, char*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:248: undefined reference to `IO_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:249: undefined reference to `PAGING_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:250: undefined reference to `MEM_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:251: undefined reference to `HARDWARE_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:252: undefined reference to `Section_prop::Add_int(char const*, int)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:253: undefined reference to `CALLBACK_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:254: undefined reference to `PIC_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:255: undefined reference to `PROGRAMS_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:256: undefined reference to `TIMER_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:257: undefined reference to `CMOS_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:264: undefined reference to `MSG_Add(char const*, char const*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:266: undefined reference to `RENDER_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:266: undefined reference to `Config::AddSection_prop(char const*, void (*)(Section*), bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:267: undefined reference to `Section_prop::Add_int(char const*, int)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:268: undefined reference to `Section_prop::Add_bool(char const*, bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:269: undefined reference to `Section_prop::Add_string(char const*, char*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:275: undefined reference to `MSG_Add(char const*, char const*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:277: undefined reference to `CPU_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:277: undefined reference to `Config::AddSection_prop(char const*, void (*)(Section*), bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:278: undefined reference to `Section_prop::Add_string(char const*, char*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:279: undefined reference to `Section_prop::Add_string(char const*, char*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:280: undefined reference to `Section_prop::Add_int(char const*, int)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:281: undefined reference to `Section_prop::Add_int(char const*, int)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:294: undefined reference to `MSG_Add(char const*, char const*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:296: undefined reference to `FPU_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:298: undefined reference to `DMA_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:299: undefined reference to `VGA_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:300: undefined reference to `KEYBOARD_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:302: undefined reference to `MIXER_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:302: undefined reference to `Config::AddSection_prop(char const*, void (*)(Section*), bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:303: undefined reference to `Section_prop::Add_bool(char const*, bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:304: undefined reference to `Section_prop::Add_int(char const*, int)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:305: undefined reference to `Section_prop::Add_int(char const*, int)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:306: undefined reference to `Section_prop::Add_int(char const*, int)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:315: undefined reference to `MSG_Add(char const*, char const*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:317: undefined reference to `MIDI_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:317: undefined reference to `Config::AddSection_prop(char const*, void (*)(Section*), bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:318: undefined reference to `MPU401_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:319: undefined reference to `Section_prop::Add_string(char const*, char*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:320: undefined reference to `Section_prop::Add_string(char const*, char*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:321: undefined reference to `Section_prop::Add_string(char const*, char*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:329: undefined reference to `MSG_Add(char const*, char const*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:335: undefined reference to `SBLASTER_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:335: undefined reference to `Config::AddSection_prop(char const*, void (*)(Section*), bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:336: undefined reference to `Section_prop::Add_string(char const*, char*)'
…Show last 75 lines
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:337: undefined reference to `Section_prop::Add_hex(char const*, int)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:338: undefined reference to `Section_prop::Add_int(char const*, int)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:339: undefined reference to `Section_prop::Add_int(char const*, int)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:340: undefined reference to `Section_prop::Add_int(char const*, int)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:341: undefined reference to `Section_prop::Add_bool(char const*, bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:342: undefined reference to `Section_prop::Add_string(char const*, char*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:343: undefined reference to `Section_prop::Add_int(char const*, int)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:353: undefined reference to `MSG_Add(char const*, char const*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:355: undefined reference to `GUS_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:355: undefined reference to `Config::AddSection_prop(char const*, void (*)(Section*), bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:356: undefined reference to `Section_prop::Add_bool(char const*, bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:357: undefined reference to `Section_prop::Add_int(char const*, int)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:358: undefined reference to `Section_prop::Add_hex(char const*, int)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:359: undefined reference to `Section_prop::Add_int(char const*, int)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:360: undefined reference to `Section_prop::Add_int(char const*, int)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:361: undefined reference to `Section_prop::Add_int(char const*, int)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:362: undefined reference to `Section_prop::Add_int(char const*, int)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:363: undefined reference to `Section_prop::Add_string(char const*, char*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:374: undefined reference to `MSG_Add(char const*, char const*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:376: undefined reference to `PCSPEAKER_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:376: undefined reference to `Config::AddSection_prop(char const*, void (*)(Section*), bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:377: undefined reference to `Section_prop::Add_bool(char const*, bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:378: undefined reference to `Section_prop::Add_int(char const*, int)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:379: undefined reference to `TANDYSOUND_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:380: undefined reference to `Section_prop::Add_string(char const*, char*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:381: undefined reference to `Section_prop::Add_int(char const*, int)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:382: undefined reference to `DISNEY_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:383: undefined reference to `Section_prop::Add_bool(char const*, bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:392: undefined reference to `MSG_Add(char const*, char const*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:394: undefined reference to `BIOS_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:394: undefined reference to `Config::AddSection_prop(char const*, void (*)(Section*), bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:400: undefined reference to `MSG_Add(char const*, char const*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:402: undefined reference to `INT10_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:403: undefined reference to `MOUSE_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:404: undefined reference to `JOYSTICK_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:405: undefined reference to `Section_prop::Add_string(char const*, char*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:408: undefined reference to `SERIAL_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:408: undefined reference to `Config::AddSection_prop(char const*, void (*)(Section*), bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:409: undefined reference to `Section_prop::Add_string(char const*, char*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:410: undefined reference to `Section_prop::Add_string(char const*, char*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:411: undefined reference to `Section_prop::Add_string(char const*, char*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:412: undefined reference to `Section_prop::Add_string(char const*, char*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:422: undefined reference to `MSG_Add(char const*, char const*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:426: undefined reference to `DOS_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:426: undefined reference to `Config::AddSection_prop(char const*, void (*)(Section*), bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:427: undefined reference to `XMS_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:428: undefined reference to `Section_prop::Add_bool(char const*, bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:429: undefined reference to `EMS_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:430: undefined reference to `Section_prop::Add_bool(char const*, bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:431: undefined reference to `Section_prop::Add_string(char const*, char*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:436: undefined reference to `MSG_Add(char const*, char const*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:438: undefined reference to `MSCDEX_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:440: undefined reference to `IPX_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:440: undefined reference to `Config::AddSection_prop(char const*, void (*)(Section*), bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:441: undefined reference to `Section_prop::Add_bool(char const*, bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:444: undefined reference to `MSG_Add(char const*, char const*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:448: undefined reference to `AUTOEXEC_Init(Section*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:448: undefined reference to `Config::AddSection_line(char const*, void (*)(Section*))'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:451: undefined reference to `MSG_Add(char const*, char const*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:452: undefined reference to `SHELL_Init()'
dosbox.o: In function `DOSBOX_RealInit':/home/safari/src/dosbox-0.65/src/dosbox.cpp:213: undefined reference to `MSG_Init(Section_prop*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:215: undefined reference to `MAPPER_AddHandler(void (*)(bool), MapKeys, unsigned long, char*, char*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:220: undefined reference to `CommandLine::FindString(char*, std::basic_string<char, std::char_traits<char>, std::allocator<char> >&, bool)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:221: undefined reference to `Section_prop::Get_string(char const*)'
:/home/safari/src/dosbox-0.65/src/dosbox.cpp:227: undefined reference to `GFX_ShowMsg(char*, ...)'
dosbox.o: In function `DOSBOX_Init()':/home/safari/src/dosbox-0.65/src/dosbox.cpp:452: undefined reference to `Config::SetStartUp(void (*)())'
collect2: ld returned 1 exit status
make[3]: *** [dosbox] Error 1
make[3]: Leaving directory `/home/safari/src/dosbox-0.65/src'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/safari/src/dosbox-0.65/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/safari/src/dosbox-0.65'
make: *** [all-recursive-am] Error 2
Thank you for your consideration, I will try to compile it on the 32-bit version of ubuntu dapper a bit later... .63 works fine on both (32 and 64-bit dapper).
Reply 1 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
please post the linking command.
It's directly above the first errror you posted.
Water flows down the stream
Reply 2 of 7, by boyofdestiny
Here it is 😀
g++ -DHAVE_CONFIG_H -I. -I. -I..  -I../include -I/usr/include/SDL -D_REENTRANT -g -O2 -c dosbox.cpp
g++ -g -O2 -o dosbox dosbox.o -lSDL_sound -lasound -lm -ldl -lpthread -L/usr/lib -lSDL -lpng -lz -lSDL_net -lGL
Thanks, I'm still a little new to Linux 😀
Here is the output of gcc -v in case that helps
gcc -v
Using built-in specs.
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --enable-languages=c,c++,java,f95,objc,ada,treelang --prefix=/usr --enable-shared --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --enable-nls --program-suffix=-4.0 --enable-__cxa_atexit --enable-clocale=gnu --enable-libstdcxx-debug --enable-java-awt=gtk-default --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-4.0-1.4.2.0/jre --enable-mpfr --disable-werror --enable-checking=release x86_64-linux-gnu
Thread model: posix
gcc version 4.0.3 (Ubuntu 4.0.3-1ubuntu3)
Reply 3 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
that link command is just wrong.
Only dosbox.o is linked. There should be a a lot of other files there.
here is what mine looks like
g++  -O2   -o dosbox  dosbox.o cpu/libcpu.a debug/libdebug.a dos/libdos.a fpu/libfpu.a  hardware/libhardware.a gui/libgui.a ints/libints.a misc/libmisc.a shell/libshell.a hardware/serialport/libserial.a  -lasound -lm -ldl -lpthread -L/usr/lib -lSDL -lcurses -lpng -lz -lGL
Reply 4 of 7, by boyofdestiny
I see... Is there something I can do to correct this?
I just do the basic ./autogen.sh, configure, make...
Are there any errors to look for?
./autogen.sh Generating build information using aclocal, autoheader, automake and autoconf This may take a while ... automake: c […]
./autogen.sh
automake: configure.in: version `' doesn't follow Gnits standards
src/Makefile.am:8: dosbox_LDADD defined both conditionally and unconditionally
Now you are ready to run ./configure.
Thanks for your patience, just learning as I go with this...
Reply 5 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
hmm yes that looks like a problem that
you might want to do without the ./autogen.sh and use the original 0.65 source.
Reply 6 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
It would be interresting to know your version of automake though. Then I can fix the problem for a next version of dosbox.
Reply 7 of 7, by boyofdestiny
That solved it. 😀
Looks awesome!
Thanks again!
As for automake, I have 1.4,1.7,1.8, and 1.9 installed. I'm not sure which it defaults to...
