Premier Manager3 problem
First post, by pearljamslion
Hi after mounting the folder then trying to run the install file it says "cannot find read me file" what do I have to do?
thanks
Reply 1 of 1, by Lofty
What are you trying to run it under?
If DosBox, you're more likely to get help in the "DosBox Games/Apps" section.
Please give us more info (Operating System, whether you're running the game from CD, and dosbox version if that's what you're using).
