First post, by AcidRulez
I am trying to make Acclaims game D to work with DOSBox. I mount my cd-rom drive and c drive. I type install and the install menu opens. I push accept configuration and the game is installed. I click continue. Then the screen says: Can you read this?
Then I can't do anything. If I look at the status window. It goes crasy with illegal read/illegal write messanges.
Does anyone know what to do next?
Reply 1 of 1, by Jiri
The game should work even if install crashed. Run Laura.bat in the game directory. You can also setup sound with sound.bat.
