running warcraft 2
First post, by sWARM
well it all startet with that i tryed to play warcraft2, i managed to install it in windows xp and run it.
but when i enter the game the sound is choppy and scroll is way to fast. thats when i found this grate program dosbox.
i can get it to run warcraft 2 but for some reason it dosent finde the warcraft 2 cd. i have no idea how to mount the game and the cd if any one could help me with this i would become really happy
my drives are as follows
c:\war2 warcraft folder
d:\ hard drive
e:\ dvd drive
f:\ warcraft cd drive
g:\ dvd drive
i am running dosbox 0.65
Reply 1 of 9, by Xelasarg
- Run Dosbox
- Type the following:
mount c C:\
mount d F:\ -t cdrom -aspi
this will mount your hard drive as drive C (obviously), and your WC2 cd drive as drive D. I'd recommend this as some older games have serious trouble with recognizing cd drives other than D or E (don't know about WC2, though).
Next you should reinstall WC2 via DOSBox to make sure you've got the right drive letter.
"What's a paladin?!"
Reply 2 of 9, by sWARM
tnx for the help, i have installed warcraft 2 thru dosbox but it still cant finde the cd when i mount the cd i get an error that says
MSCDEX: Failure: Path not vaild. dont know if that is the problem.
Reply 3 of 9, by Lofty
Hmm. Try -ioctl instead of -aspi.
Reply 4 of 9, by sWARM
woohoo it works thanks to both of you for the help. game play is a little choppy but that should be fixabel with f7 and f8
Reply 5 of 9, by Lofty
Just for future reference, mounting drive C: as C:\ can be a little risky. It's safer to put dos games in a folder and mount that as C:\, eg. mount C C:\oldgames
Reply 6 of 9, by sWARM
thanks agin 1 small thing is there a way to run dosbox in full screen
Reply 8 of 9, by Flipblade
I'm having the same problem with Warcraft II. I've tried following the above advice.
mount c c:\games\wc2
mount d e:\ -t cdrom -ioctl
I then get the message
MSCDEX installed.
Drive D is mounted as CDRom.
Warcraft will run fine but will not find the CD when going to start a single player game.
Any help would be appreciated because my wife will kill me if I don't get this working for her 😀
Reply 9 of 9, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
There is a file war2.ini.
Change cdpath=x to cdpath=d:\
1+1=10
