First post, by heiner
Hard to say which thread this should be, the problems are more related to DOS although the issue is to run it in a Win XP environment.
And the solution has to do with DOS emulation, which partially leads to DOSBox, but that doesn't really resolve it.
Anyone here who has experience?
I'd like to discuss some issues because the Windows built-in emulator appears not to work anymore since the last Windows update.
Reply 1 of 1, by dvwjr
The NTVDM in WinNT/2K/XP/2003 works just fine. Your default AUTOEXEC.NT and CONFIG.NT located in "\Windows\System32" just got trashed. You can find backup copies in "\Windows\Repair" to copy to the above named directory "\Windows\System32" to fix your problem.
dvwjr
