First post, by KieranC
Hi,
I'm using dosbox to run an old accounts package (opera) on XP, it works nicely except that to change the date in it, you have to press ctrl-f8, which obviously doesn't work. is it possible to manually send a ctrl-f8 signal to the app, or change the key combo dosbox uses for that function?
Thanks
